Loading In the Memory
Posted: Mon Feb 11, 2013 10:50 pm
I have ad great success loading standard code and even modifying it a bit. I just picked up an LED that would be hooked to the relay outlets, but will run off the PWM channels.
To allow me to control it from my phone and slate applications (Android) I need to load it the memory. I run the wizard and check the load in memory and it uploads fine. Then the screen on the RA display tells me I should now load the INO file. So now I'm confused. What am I doing wrong? Do I load into the memory, then load the same thing as an INO? I've read here were after uploading in the memory you have to make changes in a Iphone or Android ap, but that confuses me more. Can anyone offer an easy to uderstand (for me) explaination.
Thanks all, I post here and you all solve my issues!
Fat
Fat
