ph probe has a bubble
Posted: Thu Feb 14, 2013 5:43 am
by dnastynice
MY probe is screwed up and doesnt work. worked for about 3 months. it will not calibrate just reads 7 no matter what. was reading 1,3 for a while. there is a bubble in the tip is this probe shot out so soon or is there a trick to fixing it? i have 7.0 and 10.00 to calibrate but doesn't work.
Re: ph probe has a bubble
Posted: Thu Feb 14, 2013 10:14 am
If there is a bubble, you need to get it out of there. Shake it and it should make it rise.
The tip should be filled with liquid and not air.
Posted: Thu Feb 14, 2013 6:59 pm
by dnastynice
ok ill try that thanks
