http access to Reef Angel
Posted: Sun Sep 04, 2011 9:18 am
I've got error when I try to see the http page on Internet Explorer
It's says "Please wait Loading"
Librairies : V.8.5.16
My scketch :
My scketch :
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Pump1 8
#define DrainPump 7
#define Osmoseur 6
#define CO2 5
#define Heater 4
#define Bubbles 3
#define Light2 2
#define Light1 1
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "xender";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "NA";
prog_char probe3_label[] PROGMEM = "NA";
prog_char relay1_label[] PROGMEM = "Light%201";
prog_char relay2_label[] PROGMEM = "Light%202";
prog_char relay3_label[] PROGMEM = "Bubbles";
prog_char relay4_label[] PROGMEM = "Heater";
prog_char relay5_label[] PROGMEM = "CO2";
prog_char relay6_label[] PROGMEM = "RO%20Osmoseur";
prog_char relay7_label[] PROGMEM = "Drain%20Pump";
prog_char relay8_label[] PROGMEM = "Pump%201";
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.Relay.On(Port8);
ReefAngel.StandardHeater(Heater,842,860); // Setup Heater to turn on at 78.9F and off at 79.1F
//WifiAuthentication("xender:test");
ReefAngel.Timer[4].SetInterval(60); // set interval to 120 seconds
ReefAngel.Timer[4].Start();
// Specific functions
ReefAngel.StandardLights(Port1);
ReefAngel.MHLights(Port2);
ReefAngel.StandardHeater(Port4);
// Web Banner stuff
ReefAngel.WebBanner();
//CO2
if ( ReefAngel.Params.PH <= 600 )
ReefAngel.Relay.Off(Port5);
if ( ReefAngel.Params.PH >= 650 )
ReefAngel.Relay.On(Port5);
//Bubbles
if ( ReefAngel.Params.PH <= 580 )
ReefAngel.Relay.On(Port3);
if ( ReefAngel.Params.PH >= 595 )
ReefAngel.Relay.Off(Port3);
//Chiller
if ( ReefAngel.Params.Temp1 >=315 )
ReefAngel.PWM.SetDaylight(100);
if ( ReefAngel.Params.Temp1 <=300 )
ReefAngel.PWM.SetDaylight(0);
if (hour()>23 || hour()<7)
ReefAngel.PWM.SetActinic(PWMSlope(23,0,7,0,0,MoonPhase(),90,ReefAngel.PWM.GetActinicValue()));
byte MoonPhase()
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m=month();
d=day();
y=year();
yy=y-((12-m)/10);
mm=m+9;
if (mm>=12) mm-=12;
K1=365.25*(yy+4712);
K2=30.6*mm+.5;
K3=int(int((yy/100)+49)*.75)-38;
J=K1+K2+d+59-K3;
V=(J-2451550.1)/0.29530588853;
V-=int(V/100)*100;
V=abs(V-50);
PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
//pinMode(lowATOPin,OUTPUT);
return (PWMvalue*100)/255;
}Code: Select all
Détails de l’erreur de la page Web
Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET CLR 2.0.50727; .NET4.0C; .NET4.0E)
Horodateur : Sun, 4 Sep 2011 16:15:23 UTC
Message : 'x' a la valeur Null ou n'est pas un objet.
Ligne : 74
Caractère : 4
Code : 0
URI : http://www.reefangel.com/wifi/ra1.js
