Dosing schedule
Posted: Fri Feb 15, 2013 8:20 am
by Saltgator
This might be a newbie question or already brought up, but is there anyway to change the dosing pump schedule in the Wizard from minutes and seconds to hours and minutes? I'd like to be able to dose my ALK every 3ish hours, but that conflicts with the seconds the pump is turned on utilizing the Wizard (it maximum seconds on is 244 seconds I believe). Btw, my dosing pumps are 1.1mL per minute. Thanks
Country Boy using tapatalk on his EVO
Re: Dosing schedule
Posted: Fri Feb 15, 2013 8:59 pm
by Saltgator
TTT
Dosing schedule
Posted: Sat Feb 16, 2013 5:09 pm
I guess not through the wizard, but you could do whatever you want in custom code. What are you looking for specifically?
Re: Dosing schedule
Posted: Sat Feb 16, 2013 8:17 pm
by Saltgator
lnevo wrote:I guess not through the wizard, but you could do whatever you want in custom code. What are you looking for specifically?
Mainly looking to set the dosers to dose x amount every 3 hours (right now would be 7 minutes every 3rd hour would be great). I intend this smallish amount to increase over time as my corals and clams grow in a 240.
Re: Dosing schedule
Posted: Sun Feb 17, 2013 9:59 am
You can use this:
ReefAngel.DosingPumpRepeat( Port1,0,180,420 );
Or use the Wizard
