Salinity Temp Compensate's Reading
Posted: Mon Feb 18, 2013 8:26 am
by Dugong
So, according to this post
http://forum.reefangel.com/viewtopic.php?p=7386#p7386, it could be done using the following code:
double SalCompensation;
if (TempSensor.unit)
SalCompensation=Params.Salinity/(1+((Params.Temp[T1_PROBE]-250)*0.0024));
SalCompensation=Params.Salinity/(1+((Params.Temp[T1_PROBE]-770)*0.001333));
Params.Salinity=round(SalCompensation);
And I'm planning to calibrate the salinity probe using the solution with 25C temperature. The question is, where do I put above code? Is it in the setup() function? Thanks.
Re: Salinity Temp Compensate's Reading
Posted: Mon Feb 18, 2013 8:56 am
Do you plan on calibrating at 25C and monitoring at various different temperature ranges?
Posted: Mon Feb 18, 2013 5:30 pm
by Dugong
rimai wrote:Do you plan on calibrating at 25C and monitoring at various different temperature ranges?
Yep.. that is it.
Posted: Mon Feb 18, 2013 6:16 pm
Please post your code.
Posted: Mon Feb 18, 2013 8:51 pm
by Dugong
here they are:
ReefAngel.FeedingModePorts = Port4Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 350 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
//blue light, on 5:20 PM, off 1 AM, 7 hours 40 minutes
//ReefAngel.StandardLights( Port1,17,20,1,0 );
//blue light on 3:00 PM, off 10:00 PM, 7 hours
ReefAngel.StandardLights( Port1,15,0,22,0 );
//white light, on 6:20 PM, off 00:01 AM, 5 hours 40 minutes
//ReefAngel.StandardLights( Port2,18,20,0,1 );
//white light, on 4:00 PM, off 9:00 PM, 5 hours
ReefAngel.StandardLights( Port2,16,0,21,0 );
//skimmer delay
ReefAngel.Relay.DelayedOn( Port4,10 );
ReefAngel.SingleATO( true,Port8,240,0 );
ReefAngel.Portal( "Dugong" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
// Main Relay Box
// Date and Time
Posted: Mon Feb 18, 2013 9:10 pm
Try this:
double SalCompensation=0;
//skimmer delay
int x,y;
// Parameters
// Salinity
if (ReefAngel.TempSensor.unit)
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T1_PROBE]-250)*0.0024));
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T1_PROBE]-770)*0.001333));
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, round(SalCompensation) );
// Main Relay Box
// Date and Time
