RA Gen File Size Issue
Posted: Thu Sep 08, 2011 11:19 am
by Rey
I created a code through RA GEN and when I try to upload to the controller, I get the "Sketch too big" error
Binary sketch size: 36540 bytes (of a 30720 byte maximum)
// Autogenerated file by RAGen (v1.0.4.92), (09/08/2011 11:16)
// RA_090811_1116.pde
#define SetupExtras
#define WavemakerSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "Rey";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "Lights";
prog_char probe3_label[] PROGMEM = "Room";
prog_char relay1_label[] PROGMEM = "LED";
prog_char relay2_label[] PROGMEM = "Sump%20Light";
prog_char relay3_label[] PROGMEM = "Powerhead%201";
prog_char relay4_label[] PROGMEM = "Powerhead%202";
prog_char relay5_label[] PROGMEM = "Heater";
prog_char relay6_label[] PROGMEM = "Fan";
prog_char relay7_label[] PROGMEM = "Sump";
prog_char relay8_label[] PROGMEM = "Not%20Used";
    // Initialize and start the web banner timer
    ReefAngel.Timer[4].SetInterval(180);  // set interval to 180 seconds
    ReefAngel.Timer[4].Start();
    ReefAngel.FeedingModePorts = B10001100;
    ReefAngel.WaterChangePorts = B10001100;
    ReefAngel.OverheatShutoffPorts = B00110000;
    ReefAngel.LightsOnPorts = B00000011;
    // Specific functions
    ReefAngel.MHLights(Port1);
    ReefAngel.Wavemaker1(Port3);
    ReefAngel.Wavemaker2(Port4);
    ReefAngel.StandardHeater(Port5);
    ReefAngel.StandardFan(Port6);
    ReefAngel.StandardATO(Port7);
    // Web Banner stuff
        ReefAngel.WebBanner();
Re: RA Gen File Size Issue
Posted: Thu Sep 08, 2011 11:53 am
by binder
That can easily happen with all those setup screens. What I would suggest doing is removing all the setup screens and using the Client Suite or my Status App to change the memory values on the controller. Most of the time you will not ever need to change the values with the controller (it can be a little cumbersome using the up & down joystick to change the values). Removing the DateTimeSetup will save a lot of space as well. If you have a wifi module (which it sounds like you do), then I would really recommend going this route. It will definitely be worthwhile and simple for you.
You may even want to look into enabling SIMPLE_MENU (have to add in manually to the ReefAngel_Features.h file). This will strip out a lot of the extra screens and reduce the file size.
Also, you can have the Client Suite update your web banner for you automatically instead of having the controller update it. Just a thought.
Posted: Thu Sep 08, 2011 12:05 pm
by Rey
Thank you very much. I should have search the forum first before I posted this. I actually found what you're suggesting from a different thread. Thank you again.
