PH probe broken?
Posted: Fri Mar 01, 2013 6:52 pm
by daniella3d
My PH probe is going crazy, all over the place. It reads 1.00, then 14.00, then some other crazy value. It started doing that today. Before that it was very stable. Is it broken?
Nothing special that I can see, no water on anything that is not meant to have water on it.
What should I do with it?
thanks.
Re: PH probe broken?
Posted: Fri Mar 01, 2013 6:56 pm
by rossbryant1956
first pull it out of the tank water and place it in a small cup of tank water and see if it stabilizes. If it does not it is either a wire than has pulled loose somewhere or a cracked or broken probe.
Posted: Fri Mar 01, 2013 6:59 pm
by daniella3d
Hope this stuff is not toxic?
I unplugged it from the RA and the RA now show a fluctuating PH between 7 and 8.5. Is that normal? or is it the RA that is the problem?
Posted: Fri Mar 01, 2013 7:14 pm
by rossbryant1956
it is almost certainly not the RA. The range fluctuation you see now is because it cannot find the probe.
Posted: Fri Mar 01, 2013 7:18 pm
by daniella3d
Ok I put it in a cup with tank water and it goes from 14 to 1. Seem to be shifting value for no reason.
I don,t see any lose wire either.
Does it need calibration after being exposed to air?
I went ahead and ordered a new one, i guess it is broken.
Posted: Wed Mar 13, 2013 2:07 pm
by daniella3d
New PH brobe is not doing any better. is the RA broken?
I put the new ph probe, calibrated it with the 7.0 and 10.0 liquid, then put it in aquarium water in a cup and it's going from 10, to 8 to what ever. It's not stable, why is that? does it need more time to stabilize? is it normal that it's going like that through a range of values?
Posted: Wed Mar 13, 2013 2:25 pm
Does it read correctly inside the calibration packets?
What are the numbers you got when calibrating?
If you place the probe in a cup with tank water, what readings do you get?
Posted: Wed Mar 13, 2013 2:40 pm
by daniella3d
I get 639 for both calibration fluid. is that normal? I put it in 7, then wait a few minutes, press the OK button, then it ask for the 10 fluid, I put it in the 10.0 fluid, wait a few minutes and press ok. Each time it was showing 639-640
The probe is now in a cup of tank water but the value is shifting a lot, going from 14, to 4, to 8 to some other values. Its not stable. So basically it is doing the exact same thing as the other probe.
Posted: Wed Mar 13, 2013 3:01 pm
There is something wrong with the controller meter if you are getting same readings with both fluids.
PM if you want to send it for repair.
Posted: Wed Mar 13, 2013 3:05 pm
by daniella3d
send it for repair?? huh...I cannot do without a controller at all. So what to do? I don't have a backup controller here.
Is it possible to send me the replacement part and I change it myself? Or send a replacement board and I return the defective one?
Posted: Wed Mar 13, 2013 3:08 pm
by daniella3d
Can you send me the replacement part and I change it myself? I cannot afford to be without a controller for weeks.
