Resuming normal lighting.
Posted: Sun Mar 03, 2013 8:43 am
by johniii
Ok so when people come over early to check out my tank I sometimes use the all lights on command. How do I resume the normal schedule without hooking up a pc or unplugging the controller.
Re: Resuming normal lighting.
Posted: Sun Mar 03, 2013 10:14 am
Lights off, which I understand is misleading.... :(
It basically cancels the Lights on mode.
Posted: Sun Mar 03, 2013 10:37 am
by johniii
When I use lights off. It doesn't turn them on at the scheduled time. It hard overrides to off.
Posted: Sun Mar 03, 2013 12:06 pm
You are talking about the joystick menu, right?
Posted: Sun Mar 03, 2013 12:27 pm
by johniii
Yes. The joystick menu.
Posted: Sun Mar 03, 2013 1:29 pm
The Lights Off menu simply cancels the override. It does not override it off.
Posted: Sun Mar 03, 2013 6:49 pm
by johniii
Mine does. If I use it the lights off it won't resume normal the next day. I will come home to No lights.
Posted: Sun Mar 03, 2013 7:59 pm
Can you post your code?
Posted: Mon Mar 04, 2013 7:33 am
by johniii
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.StandardATO( Port1,120 );
ReefAngel.StandardLights( Port2,14,0,22,0 );
ReefAngel.DosingPumpRepeat( Port3,0,120,2 );
ReefAngel.StandardLights( Port4,14,0,22,0 );
ReefAngel.DosingPumpRepeat( Port5,60,120,2 );
ReefAngel.StandardLights( Port6,14,0,22,0 );
ReefAngel.StandardHeater( Port7,785,788 );
ReefAngel.StandardHeater( Port8,785,788 );
Posted: Mon Mar 04, 2013 9:41 am
Do you have RA or RA+?
Posted: Mon Mar 04, 2013 3:04 pm
by johniii
Ra+
Sorry about the jumbled code. Tapatalk bunched it up.
edit: just unjumbled the code
Posted: Mon Mar 04, 2013 3:32 pm
I just tested it and I can't seem to replicate this issue.
If you use Serial Monitor at 57600 baud, you can get the XML data from the controller.
Send "GET /r99 " make sure there is a space at the end...
Look for <R>, <RON> and <ROFF>
R will contain the bits that should be on/off when in auto mode.
RON will contain the bit for override on
ROFF will contain the bit for override off
In auto mode, you should have RON=0 and ROFF=255
When you override your lights on, you should see RON=42 and ROFF=255
Is this what you are getting?
Posted: Mon Mar 04, 2013 4:02 pm
by johniii
just checked. Ron 42 in override. Ron 0 in auto.
everything is right now. tonight after the normal scheduled shut off i will use lights on then lights off. To see if when i get home tomorrow the lights are on. Before it was only giving a problem without the pc hooked up. when i would hook it up. they would correct.
Thank You for your help Roberto.
Posted: Mon Mar 04, 2013 4:11 pm
Make sure to check and report on roff as well since your stating it leaves things in override off...
Lee
Posted: Mon Mar 04, 2013 5:09 pm
by johniii
Roff was 255 all modes
