Couple problems
Posted: Mon Mar 04, 2013 5:21 am
by dls10
I have a couple problems with the standard reef angel controller. Everything is up to date and I am just using the
preloaded code for now. I have the wifi attachment which works just fine (just need to configure it to work outside the home network).
First the temperature probe doesn't work. I have tried all three ports and rebooted and still nothing.
Second problem is the display seems to stick at random. Sometimes after it "goes to sleep" it will come back on when
I move the joystick, sometimes its just blank. Other times it just seems to freeze randomly. The reef angel itself
still works because I can use the iphone app to cut things on and off. It seems to just be a problem with the display.
Thanks.
Re: Couple problems
Posted: Mon Mar 04, 2013 9:45 am
Was the probe like that since the beginning?
PM me for RMA number.
Re: Couple problems
Posted: Mon Mar 04, 2013 3:05 pm
by dls10
Can't pm you it says I'm a new user and I'm not authorized to use this feature.
Re: Couple problems
Posted: Mon Mar 04, 2013 3:17 pm
by Piper
I think you need 2 or 3 posts to PM, can't remember exactly. Reply to this and try again.
Re: Couple problems
Posted: Tue Mar 05, 2013 2:53 pm
by dls10
Ok, thanks.
Re: Couple problems
Posted: Tue Mar 05, 2013 2:55 pm
by dls10
One more try.
Couple problems
Posted: Tue Mar 05, 2013 4:02 pm
You can do it!
Re: Couple problems
Posted: Tue Mar 05, 2013 7:39 pm
by Ademster
Rooting for you!!!!
Re: Couple problems
Posted: Wed Mar 06, 2013 5:22 am
by dls10
I did it!!!!!!
