phone not connecting
Posted: Mon Mar 04, 2013 6:40 pm
by Ademster
since I have added expansion hub, orp, relay box, and pwm modules the phone doesn't connect.
it appears to be updating the portal and the client app. but not the phone it continues to error out.
I uninstalled the app from the phone and re-downloaded it. no change.
any ideas?
Re: phone not connecting
Posted: Mon Mar 04, 2013 6:48 pm
I think you need to increase the buffer on the wifi attachment.
You will need a serial terminal, like putty or tera term.
If you are using Mac, you can use coolterm.
Connect to the wifi attachment at 57600 baud.
To enter command mode, you need to type $$$
The use these commands:
Posted: Mon Mar 04, 2013 7:14 pm
by Ademster
Where do I enter the code?
I am using windows 7
Posted: Mon Mar 04, 2013 7:19 pm
You need to use a serial terminal like putty or tera term
Posted: Mon Mar 04, 2013 7:22 pm
by Ademster
I downloaded tera term, not sure how to use it.
Posted: Mon Mar 04, 2013 7:36 pm
Check the wifi manual.
Posted: Mon Mar 04, 2013 8:11 pm
by Ademster
Alrighty then, followed all the steps. We'll see what happens.
Posted: Tue Mar 05, 2013 5:55 am
by Ademster
worked perfect through the night, no errors! Thanks Roberto
