Help with Airport please
Posted: Mon Mar 11, 2013 5:16 pm
by Badger55
Ok so every time I set the AirPort Extreme to open port 2000 on a specific IP address the wifi controller jumps to a different ip. 5 hours and its still killing me. I give up for the night. All other functions seem to be fine and direct connect works.
Posted: Mon Mar 11, 2013 5:52 pm
Posted: Tue Mar 12, 2013 9:50 am
by Badger55
Thanks. I'll try it today.
Re: Help with Airport please
Posted: Tue Mar 12, 2013 12:05 pm
by Badger55
Not working followed the instructions to the letter, it still changes the address of the wifi adapter as soon as I set the port mapping.
Posted: Tue Mar 12, 2013 1:19 pm
by Badger55
ok not sure how I got it but I did. Now my question is how do I know that the program is running and not on some sort of override from pushing buttons on the iPad?
Posted: Tue Mar 12, 2013 1:29 pm
On the ipad if you see blue dots next to your relays they are overrides. Click them and the relays will go back to their "normally scheduled program"
Posted: Tue Mar 12, 2013 1:53 pm
by Badger55
Thanks, my code must be off because when I hit the blue dot's for ports that should be on (main pump) it shuts off.
Posted: Tue Mar 12, 2013 2:05 pm
Sounds like it..
Posted: Tue Mar 12, 2013 2:15 pm
by Badger55
Does the ra need to be plugged into the computer to use the wizard or is there a way to use wifi?
Posted: Tue Mar 12, 2013 2:29 pm
by dbmet
Computer has to be plugged in to the RA to upload code
Posted: Tue Mar 12, 2013 2:34 pm
by Badger55
Thank you
