thank you
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "feedmode- waterchg";
prog_char menu1_label[] PROGMEM = "ATO - Overheat";
prog_char menu2_label[] PROGMEM = "calibrate ph - sal";
prog_char menu3_label[] PROGMEM = "lights on - off";
prog_char menu4_label[] PROGMEM = "set date - time";
prog_char menu5_label[] PROGMEM = "version";
prog_char menu6_label[] PROGMEM = "watchdog RESET";
prog_char menu7_label[] PROGMEM = "Menu Entry 8";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.ATOClear();
ReefAngel.OverheatClear();
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.SetupCalibratePH();
ReefAngel.SetupCalibrateSalinity();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.SetupDateTime();
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.DisplayVersion();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");wdt_reset();
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Item 8");ReefAngel.DisplayMenuEntry("TEXT");
//// Initialize the menu
