Trouble with ATO Custom Variable
Posted: Fri Mar 15, 2013 5:04 pm
by MarcWake
I have my ATO in single mode and it is working fine but I copied code from the forum to set Custom Var 0 for the ATO Exceed flag. This was working fine for a while but now Custom Var 0 shows as 42 and I can't get it to reset at all. I ran the ATO to timeout and reset the unit but no luck. The ATO is functioning properly but the Custom Var is not.
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,14,0,22,0 );
ReefAngel.StandardHeater( Port2,770,780 );
ReefAngel.SingleATO( true,Port3,90,0 );
ReefAngel.StandardHeater( Port4,770,780 );
ReefAngel.StandardLights( Port6,22,0,12,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,22,0,15,100,60,15) );
ReefAngel.CustomVar[0]=InternalMemory.read(ATO_Single_Exceed_Flag);
ReefAngel.CustomVar[1]=InternalMemory.read(Overheat_Exceed_Flag);
ReefAngel.CustomVar[7]=255;
ReefAngel.Portal( "marcwake" );
Re: Trouble with ATO Custom Variable
Posted: Fri Mar 15, 2013 5:08 pm
What happens if you use Clear ATO?
Posted: Fri Mar 15, 2013 5:17 pm
by MarcWake
It will clear it and allow the ATO to work again but has no effect on the Custom Var
Posted: Fri Mar 15, 2013 6:53 pm
What value do you get when it does timeout?
Posted: Fri Mar 15, 2013 7:24 pm
by MarcWake
It stays 42 on the custom var even when it times out but it stops the ago pump properly
Posted: Sat Mar 16, 2013 9:54 am
Ok, you just found a major bug :(
The libraries are writing to memory constantly when the timeout happens.
There is no check and it is causing the memory to get corrupt.
#ifdef ENABLE_EXCEED_FLAGS
        InternalMemory.write(ATO_Single_Exceed_Flag, 1);
#endif  // ENABLE_EXCEED_FLAGS
This is probably happening to the other exceed flags too and need to be corrected.
I opened a ticket for this issue:
https://github.com/reefangel/Libraries/issues/69
In the mean time, you can edit the Globals.h file.
Replace this line:
#define ATO_Single_Exceed_Flag	  733	//747
With this:
#define ATO_Single_Exceed_Flag	  800	//733	//747
We are relocating the memory location and avoiding that particular address.
Thanks for contributing :)
Posted: Sat Mar 16, 2013 10:44 am
by MarcWake
Ok thanks that seems to have worked. When I first re-uploaded the code the exceed flag was set to 255 but once i cleared the ATO flag it seems to work properly. So does that mean that the old exceed flag memory location is corrupt forever now? Doesn't really matter just wondering. Thanks for the help RA is the best
Posted: Sat Mar 16, 2013 10:47 am
Yeah, when it gets corrupt, you shouldn't use it anymore.
EEPROM has a write repetition of thousands of cycles, but when you are writing over and over without any check, it gets there pretty quick.
Posted: Sat Mar 16, 2013 10:50 am
Just watch for timeouts until the next lib update gets released or you will end up corrupting this location too.
I'll try to give you the patch before it gets released just to ensure you won't burn that address too.
Posted: Sat Mar 16, 2013 10:51 am
i was worried about that when i did my vortech code...constantly writing memory...i made my code do a check and only write if the location has changed...may want to consider it, not sure what performance hit would be..
Posted: Sat Mar 16, 2013 11:43 am
by MarcWake
Ya I tended to leave the timeout for a day before I got to topping off my ATO container so that is probably why it happened so fast. I will try to stay on top of it till you get a fix going. Thanks again
Posted: Sat Mar 16, 2013 2:05 pm
It's a good thing you guys are finding all of these "features". :)
Posted: Sat Mar 16, 2013 4:02 pm
:) features...yeah features :)
