ReefCrest for Tunze
ReefCrest for Tunze
Hi,
Can u please help me code my pair of Tunzes to run on ReefCrest mode anti-sync?
~JaY
~JaY
Re: ReefCrest for Tunze
i saw that topic and used the code and i like it but how do i set the min speed at 30 as you arent supposed to go under that on the tunzes. I would like the max at 80 and the min at 30
ReefCrest for Tunze
Th range in that code is +/- 20 so if you set the speed at 55, you'll have a range of 75-35. If you want to increase the range to 25 which would give you 30-80, you'll need to change the s-20,s+20 line to 25's
ReefCrest for Tunze
Awesome I figured it was something simple like that. I'm still trying to get a grasp on all the coding but with the help of the board my coding is working great for me.lnevo wrote:Th range in that code is +/- 20 so if you set the speed at 55, you'll have a range of 75-35. If you want to increase the range to 25 which would give you 30-80, you'll need to change the s-20,s+20 line to 25's
Will the code work for 2 tunzes anyti-sync mode?
byte ReefCrestMode(byte s)
static unsigned long lastmillis=millis();
static int newspeed=s;
if ((millis()-lastmillis) > 5000)
int delta;
delta=random(20);
if (delta<10) newspeed--; else newspeed++;
newspeed=constrain(newspeed,s-20,s+20);
newspeed=constrain(newspeed,0,100);
return newspeed;
Try this:
byte ReefCrestMode(byte s, boolean sync)
int delta;
delta=random(20);
if (sync)
return newspeed;
return s-(newspeed-s);
Will do - Thanks once again Roberto.
ReefCrest for Tunze
Awesome I was wondering this as well.
Here's my current code - Where should I put the new code?
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardATO( Port1 );
ReefAngel.MoonLights( Port3 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Wavemaker1( Port6 );
ReefAngel.DayLights( Box1_Port1 );
ReefAngel.ActinicLights( Box1_Port2 );
ReefAngel.DayLights( Box1_Port3 );
ReefAngel.ActinicLights( Box1_Port4 );
ReefAngel.DayLights( Box1_Port5 );
ReefAngel.ActinicLights( Box1_Port6 );
ReefAngel.StandardHeater( Box1_Port7 );
if (hour()>14)
ReefAngel.PWM.SetDaylight (now()%(2*60*60)<(1*60*60)?80:35);
ReefAngel.PWM.SetActinic (now()%(2*60*60)<(1*60*60)?35:90);
ReefAngel.PWM.SetDaylight (45);
ReefAngel.PWM.SetActinic (45);
ReefAngel.PWM.SetActinic(30);
ReefAngel.PWM.SetDaylight(30);
ReefAngel.AddWifi();
int x,y;
// Relay Expansion
if (hour()>14)
int x,y;
// Relay Expansion
