Hi all, I apologize for another ATO question, but I swear this one should be easy:
- I want to set the ATO to single, using ATO Low to trigger the pump to feed the water to top off my sump.
- I want to set the ATO high as a backup switch, so if the first ATO low fails, the second will stop any overflow from happening.
Can anyone see an issue with this?
Another ATO question - single ato + backup
neuro
Re: Another ATO question - single ato + backup
Anyone help with code?
duck
this is what im using with two float switches, a 12v solenoid/valve and a wall wart.
//global
#define ATO 8
//inside void loop
//ATO Low Activation with High Safety (Port 8)
if (ReefAngel.HighATO.IsActive()) ReefAngel.SingleATOLow(ATO);
else ReefAngel.Relay.Off(ATO);
