after //////rf programmed it stays in done
Posted: Wed Apr 03, 2013 2:37 pm
by coolsilver
Hi
I just hooked up my new RA
I have quition in RF module
it was successufuly assigned as master to my 2 vortechs
with solid green LED it controlled both
but after that what should I do
the screen stays on :
assingning slaves
Done
how to continue ?
Posted: Wed Apr 03, 2013 3:28 pm
Load your new code.
Re: after //////rf programmed it stays in done
Posted: Wed Apr 03, 2013 3:34 pm
by coolsilver
where I will find the new code ?
Posted: Wed Apr 03, 2013 3:45 pm
There is a wizard or you can go back to the preloaded code.
Posted: Wed Apr 03, 2013 4:01 pm
by coolsilver
I went back to my configuration by uploading the sketch generated by wizard
the green LED turned into pink or white pink in the RF module
and it is not changing when trying to change modes from portal
same like beginning
Posted: Wed Apr 03, 2013 4:12 pm
by coolsilver
what I did after hooking up RA+ controller
finished the wizard and uploaded it
finished the WIFI configuration and sucessufly connected the portal
now when I am trying to programm the RF module (I uploaded RA+ with vortechsetup )
RF module blinking green and blue
then make bothe vortechs as slaves (after reseting the memory for them )
press the joystick
RF module become GREEN
RA+ showing (assigne slave DONE )
after that uploaded the old wizard file and the green light in RA+ became pinky white
and tried to change the mode of vortechs from portal it didnt work
whad did I miss ?
Posted: Wed Apr 03, 2013 4:13 pm
Did you add any code to enable the RF in the original code?
Posted: Wed Apr 03, 2013 4:16 pm
by coolsilver
I used the wizard and checked on RF
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.DosingPumpRepeat( Port5,0,1,10 );
ReefAngel.StandardLights( Port6,18,0,0,0 );
ReefAngel.Relay.DelayedOn( Port7,3 );
ReefAngel.StandardFan( Port8,230,270 );
ReefAngel.DosingPumpRepeat( Box1_Port5,0,60,60 );
ReefAngel.DosingPumpRepeat( Box1_Port6,0,60,50 );
ReefAngel.StandardATO( Box1_Port8,60 );
ReefAngel.RF.SetMode( TidalSwell,100,10 );
ReefAngel.Portal( "coolsilver" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,46, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,46, ReefAngel.Params.Salinity );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,63, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,63, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 79, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
// Date and Time
Posted: Wed Apr 03, 2013 4:24 pm
You are hard coding it in your code to tidal swell at 100% with a 10 second duration.
Change usememory to true if you want to set via the portal.
The tidal swell mode shows as purple on the rf module.
Posted: Wed Apr 03, 2013 4:41 pm
by coolsilver
thank you lnevo
you make me realize it it
I am able now to control it through portal I apritiate your support
