Hi everyone,
I've had a couple of instances where the status light has come on due to temperature. The units are Celcius and my temp range is 25.5 - 26.0 with overheat set to 30.0. There's absolutely now way the system is overheating, it's located right underneath a heatpump. This is actually the issue as when the heater isn't running the temperature can get suppressed quite quickly.
I'm a little concerned that I might have a faulty temp probe or that something is maybe shorting it out from time to time.
Any thoughts or feedback.
Thanks a lot.
Temperature Status Light
Re: Temperature Status Light
Yes it does which is good but also the problem. Both times I checked the tank for something unrelated and noticed the temp was in the low twenties.
I only have 1 temp probe and in my code also use it as the overheat probe. I'm assuming this is ok? Here's my sketch just in case it helps.
//*** Define only one mode ***
//#define TUNZE_MODE_SINE // sine wave, no pulse
#define TUNZE_MODE_LONG // no sine wave, long pulse
//#define TUNZE_MODE_SHORT // no sine wave, short pulse
//#define TUNZE_MODE_LONGSINE // sine wave, long pulse
//#define TUNZE_MODE_SHORTSINE // sine wave, short pulse
#define TUNZE_MIN 30
#define TUNZE_MAX 75
#define TUNZE_SINE_SEC 23400
#define TUNZE_SINE_SYNC false
#define TUNZE_LONGPULSE_SEC 5
#define TUNZE_LONGPULSE_SYNC false
#define TUNZE_SHORTPULSE_MS 500
#define TUNZE_SHORTPULSE_SYNC true
pulseMinSpeed - % for minimal speed
pulseMaxSpeed - % for maximum speed
pulseDuration - Duration (milliseconds) in which each pulse will be held. The pump will stay at minimal speed for pulseDuration and will stay at maximum speed for pulseDuration.
pulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
byte tunzeShortPulse(byte pulseMinSpeed, byte pulseMaxSpeed, int pulseDuration, boolean pulseSync) {
pulseMinSpeed = constrain(pulseMinSpeed, 30, 100);
pulseMaxSpeed = constrain(pulseMaxSpeed, 30, 100);
byte tspeed = (millis() % (pulseDuration * 2) < pulseDuration ? pulseMinSpeed : pulseMaxSpeed);
if (pulseSync) {
return tspeed;
return (tspeed == pulseMinSpeed) ? pulseMaxSpeed : pulseMinSpeed;
pulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for pulseDuration and will stay at maximum speed for pulseDuration.
byte tunzeLongPulse(byte pulseMinSpeed, byte pulseMaxSpeed, int pulseDuration, boolean pulseSync) {
byte tspeed = (now() % (pulseDuration * 2) < pulseDuration ? pulseMinSpeed : pulseMaxSpeed);
if (pulseSync) {
return tspeed;
tunzeSineWave
byte tunzeSineWave(boolean isleftpump, byte minspeed, byte maxspeed, int periodSec) {
double x = double(now() % periodSec);
x /= periodSec;
x *= 2.0 * PI;
if (!isleftpump) {
x += PI; // shift the sine wave for the right pump
double y = sin(x);// y is now between -1 and 1
y += 1.0; // y is now between 0 and 2
y /= 2.0; // y is now between 0 and 1
// now compute the tunze speed
y *= double(maxspeed - minspeed);
y += double(minspeed);
y += 0.5; // for proper rounding
// y is now between minspeed and maxspeed, constrain for safety
return constrain(byte(y), 30, 100);
runTunzes
void runTunzes(byte minSpeed, byte maxSpeed) {
#ifdef TUNZE_MODE_SINE
ReefAngel.PWM.SetDaylight(tunzeSineWave(true, TUNZE_MIN, TUNZE_MAX, TUNZE_SINE_SEC)); // left tunze
ReefAngel.PWM.SetActinic(tunzeSineWave(TUNZE_SINE_SYNC, TUNZE_MIN, TUNZE_MAX, TUNZE_SINE_SEC)); // right tunze
#endif
#ifdef TUNZE_MODE_LONG
ReefAngel.PWM.SetDaylight(tunzeLongPulse(TUNZE_MIN, TUNZE_MAX, TUNZE_LONGPULSE_SEC, true)); // left tunze
ReefAngel.PWM.SetActinic(tunzeLongPulse(TUNZE_MIN, TUNZE_MAX, TUNZE_LONGPULSE_SEC, TUNZE_LONGPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_SHORT
ReefAngel.PWM.SetDaylight(tunzeShortPulse(TUNZE_MIN, TUNZE_MAX, TUNZE_SHORTPULSE_MS, true)); // left tunze
ReefAngel.PWM.SetActinic(tunzeShortPulse(TUNZE_MIN, TUNZE_MAX, TUNZE_SHORTPULSE_MS, TUNZE_SHORTPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_LONGSINE
ReefAngel.PWM.SetDaylight(tunzeLongPulse(TUNZE_MIN, tunzeSineWave(true, TUNZE_MIN, TUNZE_MAX, TUNZE_SINE_SEC), TUNZE_LONGPULSE_SEC, true)); // left tunze
ReefAngel.PWM.SetActinic(tunzeLongPulse(TUNZE_MIN, tunzeSineWave(TUNZE_SINE_SYNC, TUNZE_MIN, TUNZE_MAX, TUNZE_SINE_SEC), TUNZE_LONGPULSE_SEC, TUNZE_LONGPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_SHORTSINE
ReefAngel.PWM.SetDaylight(tunzeShortPulse(TUNZE_MIN, tunzeSineWave(true, TUNZE_MIN, TUNZE_MAX, TUNZE_SINE_SEC), TUNZE_SHORTPULSE_MS, true)); // left tunze
ReefAngel.PWM.SetActinic(tunzeShortPulse(TUNZE_MIN, tunzeSineWave(TUNZE_SINE_SYNC, TUNZE_MIN, TUNZE_MAX, TUNZE_SINE_SEC), TUNZE_SHORTPULSE_MS, TUNZE_SHORTPULSE_SYNC)); // right tunze
#endif
byte PORT_TUNZE_1 = Port1;
byte PORT_TUNZE_1_BIT = Port1Bit;
byte PORT_TUNZE_2 = Port2;
byte PORT_TUNZE_2_BIT = Port2Bit;
byte PORT_SKIMMER = Port3;
byte PORT_SKIMMER_BIT = Port3Bit;
byte PORT_ATO = Port4;
byte PORT_ATO_BIT = Port4Bit;
byte PORT_RETURN = Port5;
byte PORT_RETURN_BIT = Port5Bit;
byte PORT_LED = Port6;
byte PORT_LED_BIT = Port6Bit;
byte PORT_HEATER = Port7;
byte PORT_HEATER_BIT = Port7Bit;
byte PORT_DOSING = Port8;
byte PORT_DOSING_BIT = Port8Bit;
Setup
void setup() {
ReefAngel.Init(); // Initialize Controller
ReefAngel.AddWifi();
ReefAngel.AddStandardMenu();
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = PORT_ATO_BIT | PORT_SKIMMER_BIT | PORT_RETURN_BIT | PORT_TUNZE_1_BIT | PORT_TUNZE_2_BIT;
ReefAngel.WaterChangePorts = PORT_ATO_BIT | PORT_SKIMMER_BIT | PORT_RETURN_BIT | PORT_TUNZE_1_BIT | PORT_TUNZE_2_BIT;
ReefAngel.OverheatShutoffPorts = PORT_HEATER_BIT;
ReefAngel.LightsOnPorts = PORT_LED_BIT;
ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
ReefAngel.Relay.On(PORT_TUNZE_1);
ReefAngel.Relay.On(PORT_TUNZE_2);
ReefAngel.Relay.On(PORT_SKIMMER);
ReefAngel.Relay.On(PORT_RETURN);
ReefAngel.Relay.On(PORT_LED);
ReefAngel.Relay.On(PORT_DOSING);
ReefAngel.SetTemperatureUnit(Celsius);
Loop
void loop() {
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE, COLOR_WHITE, 28, 121, "JVR Reef"); // Display Reef Angel banner
ReefAngel.StandardATO(PORT_ATO);
ReefAngel.StandardHeater(PORT_HEATER);
long h = hour();
byte minSpeed = h > 20 || h < 8 ? 30 : 50;
byte maxSpeed = h > 20 || h < 8 ? 75 : 100;
runTunzes(minSpeed, maxSpeed);
ReefAngel.Portal("bubbles");
I've added a trouble ticket to extend the overheat check to a couple seconds instead of instantaneous.
https://github.com/reefangel/Libraries/issues/78
Noise in the temp probe lead can cause abnormal temperature readings, but they are usually very fast... Only a fraction of a second.
Awesome. This will flow through as a library update then?
Yes it will once it is completed and tested.bubbles wrote:Awesome. This will flow through as a library update then?
YAY! I cant wait. I get a 130+ F degree instantaneous split second reading that trips my overheat constantly. It's really annoying.binder wrote:Yes it will once it is completed and tested.bubbles wrote:Awesome. This will flow through as a library update then?
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
