Help with 1st time coding
Posted: Sat Apr 06, 2013 8:49 am
Good Day All,
Still trying to setup my RA
I need assistance with my code
I want a very basic menue
1. Lights on/off (port 1 to 4)
2. Skimmer on/off (port7)
3. Return on/off (port8)
4. Setup - Calibrate pH
Info on Ports
Port 1 - 4 Lights
Port 5 Fans 26.5 on 26 off
Port 6 Heaters 25.5 on 26 off
Light time
Actinic Lights - Port 1
9:15 to 6:15
Daylight Lights Port 2
9:45 to 6:15
Actinic Lights Port 3
10:15 to 7:45
Daylight Lights Port 4
10:45 to 5:45
Here is my code so far but it is not working 100%, my lights does not want to switch on/off via the menu on the controller
ReefAngel.AddStandardMenu();
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit; // Turn on/off Ports 1 and 2 and 3 and 4 when Light On/Off menu option is selected
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,15,18,15 ); // Actinic Lights
ReefAngel.StandardLights( Port2,9,45,18,15 ); // Daylight Lights
ReefAngel.StandardLights( Port3,10,15,19,45 ); // Actinic Lights
ReefAngel.StandardLights( Port4,10,45,17,45 ); // Daylight Lights
ReefAngel.StandardFan( Port5,260,265 );
ReefAngel.StandardHeater( Port6,255,260 );
ReefAngel.Portal( "Express Reef" );
ReefAngel.ShowInterface(); // Display everything on the LCD screen
Info on Ports
Port 1 - 4 Lights
Light time
9:15 to 6:15
9:45 to 6:15
10:15 to 7:45
10:45 to 5:45
