Function pointer inside our own class
Posted: Sun Apr 07, 2013 12:13 pm
Hey Everyone,
I'm getting confused and can't get this to work.
Is it possible to have a pointer to a function inside our own class?
The class in reference is the ReefAngelClass and function is FeedingModeStart();
Example:
typedef void (* FuncPtr) (); // declare function pointers
FuncPtr test=FeedingModeStart;
Maybe I'm going the wrong path....
So, let me give you an overview of what I'd like to do.
I'd like to have an array of function pointers that I can call by using the array reference.
Something like:
FuncPtr myarray={FeedingModeStart,WaterChangeModeStart};
This way I can call, for example:
I know I can do this outside of the class, but how would I do this from within?
Anyone have any ideas?
Posted: Sun Apr 07, 2013 12:19 pm
I think you need to do this
myarray[0]();
But should be doable.
Posted: Sun Apr 07, 2013 12:20 pm
I don't think it would be any different than calling another function inside the class.
Outside the class it could still be called if it were public
ReefAngel.myarray[0]();
Re: Function pointer inside our own class
Posted: Sun Apr 07, 2013 12:23 pm
The problem is that I can't even get past the compiler
The compiler doesn't like the function to be inside of the class.
I get this error:
error: argument of type 'void (ReefAngelClass::)()' does not match 'void (*)()'
on this line:
Posted: Sun Apr 07, 2013 12:34 pm
Maybe define the typedef as
void (ReefAngelClass::*FunctPtr)()
Check this url for another example.
http://stackoverflow.com/questions/9906 ... r-function
Posted: Sun Apr 07, 2013 12:46 pm
I had tried that already and gives me another error:
'FuncPtr' was not declared in this scope
Posted: Sun Apr 07, 2013 12:53 pm
Sorry...
My bad...
The error is this:
error: argument of type 'void (ReefAngelClass::)()' does not match 'void (ReefAngelClass::*)()'
Posted: Sun Apr 07, 2013 12:56 pm
And if I do this:
typedef void (ReefAngelClass::* FuncPtr) (); // declare function pointers
FuncPtr test=&FeedingModeStart;
I get this:
error: ISO C++ forbids taking the address of an unqualified or parenthesized non-static member function to form a pointer to member function. Say '&ReefAngelClass::FeedingModeStart'
Posted: Sun Apr 07, 2013 1:01 pm
I think I got it...
Thanks for that link. It led me to another one that pointed me to add the class in front of the function too.
Let me test it out
FuncPtr test=&ReefAngelClass::FeedingModeStart;
Posted: Sun Apr 07, 2013 1:03 pm
Try the suggestion
FuncPtr test=&ReefAngel::FeedingModeStart;
Posted: Sun Apr 07, 2013 1:04 pm
Cool saw your post after mine...
