error with ra preloaded code
raymond_q
this is the error it was to big to put on here so I attached it to notepad
Re: error with ra preloaded code
Do you get this error everytime you try to upload any code?
raymond_q
I am not sure this is the only 1 I have tried.
raymond_q
i just loaded a new code with wizard and this is what I got
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 27,464 bytes (of a 30,720 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM4 -b57600 -D -Uflash:w:C:\Users\RAYMOND\AppData\Local\Temp\build5749569528960650357.tmp\sketch_apr09a.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean
Using Port : \\.\COM4
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
avrdude done. Thank you.
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
avrdude: Recv:
raymond_q
i have it on ra controller
If you have the standard RA, please select w/ optiboot option.
raymond_q
ok did that. now it seems like the attached error code comes up again
So, is it doing it every time?
Were you ever able to upload any code successfully?
raymond_q
yes the code seems to be on the ra but it still has the errors on the arduino program.
raymond_q
ill swing by on friday to drop the unit
