RA hanging or heater relay clicking
Posted: Tue Apr 09, 2013 2:39 pm
I'm new to RA. I received mine last week and have been working to get it up and running.
I have a couple different issues.
I have the RF expansion, water lever expansion, salinity expansion, and WiFi.
I have been successful getting WiFi working, my 2 Vortech 40mp to sync and change modes. Water lever expansion works and turns on and off ATO pump. Salinity is up and calibrated. So I have all the expansion working.
Now here is where my problems come in. I am using the wizard to make the file and not really doing anything other than adding the line of code for the water lever expansion. I'm just trying to make sure everything work before I start complicating things by adding custom code.
When I have the RF code installed and the system is up and running for an hour or so the system hangs. The green LED is on steady, the red LED flashes 3 times. After the 3 flashes the back light comes on the LCD for a second or two, then the red LED flashes 3 times again. And this continues to repeat until I unplug the power and re-apply it.
I have tried using internal and external memory and both have the same out come.
Problem #2 - I removed the RF expansion from the wizard and built a new file with out it to see if I could get the rest of the system up and running. I have the 2 dosing pumps (I want to add a 3rd) working correctly and it looks like the ATO is functioning correctly.
I'm running a 500W Finnex Titanium heater and it is on port 3 on the relay box. Everything works great until the RA turns on the heater at that point the relay clicks continuously until I remove power from the system.
Any ideas?
Any ideas?
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port3,778,772 );
ReefAngel.WaterLevelATO(Port5,30,81,83);
ReefAngel.DosingPumpRepeat( Port6,0,120,1 );
ReefAngel.DosingPumpRepeat( Port7,45,60,1 );
ReefAngel.Portal( "Endaar" );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
// Date and Time
