PH Expansion
Posted: Wed Apr 10, 2013 8:27 pm
by stevengreen2
Is there something wrong with my code. I changed it today for my PH expansion to handle my calcium reactor and I can't get it to work right off of my PH Expansion.
Here is my code:
#define WDT
#define NUMBERS_8x16
#include <avr/pgmspace.h>
  ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
  ReefAngel.StandardHeater( Port1,780,790 );
  ReefAngel.SingleATO( true,Port3,300,0 );
  ReefAngel.StandardLights( Port4,9,0,22,0 ); //LED Fans
  ReefAngel.StandardLights( Port6,9,0,22,0 ); //UV LED
  ReefAngel.StandardLights( Port7,11,0,20,0 ); //DR-Cyan LED
  ReefAngel.StandardLights( Port8,22,0,9,30 ); //SUMP LIGHT
  ReefAngel.PWM.SetDaylight( PWMSlope(10,0,21,0,10,100,30,10) ); //BLUE LED
  ReefAngel.PWM.SetChannel( 0, PWMSlope(9,0,22,0,10,100,60,10) ); //RB LED
  ReefAngel.PWM.SetChannel( 1, PWMSlope(10,30,21,0,10,55,120,10) ); //CW LED
  ReefAngel.PWM.SetChannel( 2, PWMSlope(10,30,21,0,10,75,120,10) ); //CW LED
if ( ReefAngel.Params.PHExp < 665 ) ReefAngel.Relay.Off(Box1_Port2); //CO2 Switch
if ( ReefAngel.Params.PHExp >= 680 ) ReefAngel.Relay.On(Box1_Port2); //CO2 Switch
  ReefAngel.AddWifi();
  byte x = 6;
  byte y = 2;
  byte t;
  // Parameters
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.Clear(COLOR_SLATEGREY, 1, 11, 132, 11);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,12,16,"Steve's Reef", Font8x16);
  ReefAngel.LCD.DrawText(COLOR_BLUE,255, 6, 101, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLUE,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLUE,255,10,30,"TANK");
  ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 15, 40, text, Num8x16);
  ReefAngel.LCD.DrawText(COLOR_BLUE,255,85,30,"CR pH");
  ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 85, 40, text, Num8x16);
  // Main Relay Box
  ReefAngel.LCD.DrawOutletBox(12, 87, TempRelay);
  ReefAngel.LCD.DrawText(COLOR_BLUE,255,12,58,"Room");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 15, 68, text, Num8x16);
  ReefAngel.LCD.DrawText(COLOR_BLUE,255,81,58,"Tank pH");
  ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 85, 70, text, Num8x16);
  ReefAngel.LCD.DrawText(0,255,15,109, "RB");
  ReefAngel.LCD.DrawText(COLOR_SLATEGREY,255,14,119, ReefAngel.PWM.GetChannelValue(0));
  ReefAngel.LCD.DrawText(0,255,105,109, "CW");
  ReefAngel.LCD.DrawText(COLOR_SLATEGREY,255,106,119, ReefAngel.PWM.GetChannelValue(1));
  ReefAngel.LCD.DrawText(0,255,55,109, "BLUE");
  ReefAngel.LCD.DrawText(COLOR_SLATEGREY,255,60,119, ReefAngel.PWM.GetDaylightValue());
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights7' /
// Main Relay Box
// Date and Time
Re: PH Expansion
Posted: Wed Apr 10, 2013 9:12 pm
It looks good.
What is it doing?
Re: PH Expansion
Posted: Wed Apr 10, 2013 10:19 pm
by stevengreen2
Well the PH is 7.22 right now and port 2 is not on.
Re: PH Expansion
Posted: Thu Apr 11, 2013 8:03 am
The code looks good.
Can you test the relay expansion to see if you can control it and it communicates with the head unit?
Re: PH Expansion
Posted: Thu Apr 11, 2013 8:51 am
by stevengreen2
Yeah, I can turn off/on port 2 with my phone just fine. I used to have port 2 configured for C02 with the regular PH from the controller.
Re: PH Expansion
Posted: Thu Apr 11, 2013 9:05 am
So let's check the pH expansion.
Are you sure it is working?
The 7.22 value you mentioned, is it the one displayed as CR pH?
Re: PH Expansion
Posted: Thu Apr 11, 2013 9:18 am
by stevengreen2
Yeah, the PH expansion is going to my Calcium Reactor and it is showing 7.72 now
Re: PH Expansion
Posted: Thu Apr 11, 2013 10:34 am
Humm... not sure what the issue is :oops:
Everything looks correct.
Re: PH Expansion
Posted: Thu Apr 11, 2013 7:04 pm
I have a couple comments.
1. This line at the end shouldn't be there. I'm not exactly sure what it is doing either:
// Parameters
// Main Relay Box
This line is just hanging out outside of all the normal functioning code. It should probably be removed.
2. Next, I see no reference to an expansion relay box HOWEVER your custom CO2 code is using the 1st expansion box and port 2 on it and not on the main relay.
I think this should be changed to this to work:
if ( ReefAngel.Params.PHExp < 665 ) ReefAngel.Relay.Off(Port2); //CO2 Switch
if ( ReefAngel.Params.PHExp >= 680 ) ReefAngel.Relay.On(Port2); //CO2 Switch
Otherwise it is trying to toggle a relay that doesn't exist.
Re: PH Expansion
Posted: Sat Apr 13, 2013 3:11 pm
by stevengreen2
Thanks so much guys, that did it. That code was just left from copying somebody's elses code from the forum. I'm so glad that no matter what issue I have with this reef angel it can be fixed fast.
