manually turning on relay box ports?
Posted: Fri Apr 12, 2013 11:25 am
by pandimus
So how do i manually operate relay box ports? i/e want to turn off skimmer to clean it?
Re: manually turning on relay box ports?
Posted: Fri Apr 12, 2013 11:54 am
by bencollinz
the portal, your smartphone or PC
http://forum.reefangel.com/portal.php
http://www.reefangel.com/download.aspx
click contributions.
all of those require your knowing how to forward a port in your router and using a service like dyndns.org, etc.
you really gotta do some searching and read some more.
Posted: Fri Apr 12, 2013 11:57 am
by pandimus
Did search,and dont have wifi module.
Posted: Fri Apr 12, 2013 12:01 pm
by bencollinz
ahh, see, you didn't state that.
Posted: Fri Apr 12, 2013 12:02 pm
PC client connected via USB is probably your best bet. The other method is to define the ports you want to shut down for maintenance and use them and program that as your ReefAngel.WaterChangePorts then for maintenance you would just go into waterchange mode from the existing method and all your pumps / skimmer / reactors whatever you would do would shutdown during that time.
Posted: Fri Apr 12, 2013 12:43 pm
by pandimus
I guess water change mode it is until I get an ip address to it.
