pwm voltage?
pandimus
pwm voltage?
Post by pandimus »
I thought i read somewhere that pwm voltage should be between 0-10vdc. now i was trying to figure out how to make it 5v max, and couldnt find anything. Then i went and rechecked the products page and it says 10vdc. Can it be adjusted and how? i am assuming i can code it to make maximum 50%. I am talking about straight from the relay box. not the expansion.
thanks
Johnny
pwm voltage?
You can use the map function.
http://arduino.cc/en/Reference/map
Re: pwm voltage?
You will need to remove the booster from the relay box and solder some jumper wires.
Even at 50%, the signal is still 0-10vdc, with 50% duty cycle.
Sent from my Galaxy S3 using Tapatalk 2
pandimus
Re: pwm voltage?
Post by pandimus »
rimai wrote:You will need to remove the booster from the relay box and solder some jumper wires.
just jumper it straight across where the pins used to be? or is there an order?
Re: pwm voltage?
You need to remove lm358 and resistors.
Then, connect the in to out with jumper wires
pandimus
Re: pwm voltage?
Post by pandimus »
Will do thanks.
Re: pwm voltage?
I guess it was more involved than i thought :) sorry :)
pandimus
Re: pwm voltage?
Post by pandimus »
Not a problem at all.
pandimus
Re: pwm voltage?
Post by pandimus »
Easy mod.just De solder like said then connect jumpers from + volts in to out on both sides of the lm358...Thanks
mls228
pwm voltage?
Post by mls228 »
I have my relay box open now. Can you guys describe in terms of pins what to do? Thanks!
Re: pwm voltage?
Jumper 1 and 3 together and 5 and 7 together.
mls228
pwm voltage?
Post by mls228 »
rimai wrote:You need to remove lm358 and resistors.
Sorry to ask again. "Measure twice, cut once."
I'll remove R19, R20, R21, R22 and the LM358 (IC1), then jumper as described. Correct?
Re: pwm voltage?
Yes.
baroutas
Re: pwm voltage?
Post by baroutas »
Roberto if i want change the actinic port from 0-10 to PWM and oposite what must do or remove?
Re: pwm voltage?
Unless you have one of the latest board revisions (rev 8.1), it will be very hard for you to do this.
baroutas
Re: pwm voltage?
Post by baroutas »
How can i see that? I order my RA Noveber 2012.
Re: pwm voltage?
Opening the box, but I'm almost positive the rev 8.1 wasn't around at that time.
baroutas
Re: pwm voltage?
Post by baroutas »
ok!!!Thanks Roberto!
mls228
Re: pwm voltage?
Post by mls228 »
Life got in the way but 8 months later I made this change and it works perfectly. Thanks Roberto. Image
