pwm voltage?
Posted: Sun Apr 14, 2013 12:26 pm
by pandimus
I thought i read somewhere that pwm voltage should be between 0-10vdc. now i was trying to figure out how to make it 5v max, and couldnt find anything. Then i went and rechecked the products page and it says 10vdc. Can it be adjusted and how? i am assuming i can code it to make maximum 50%. I am talking about straight from the relay box. not the expansion.
thanks
Johnny
pwm voltage?
Posted: Sun Apr 14, 2013 12:41 pm
You can use the map function.
http://arduino.cc/en/Reference/map
Re: pwm voltage?
Posted: Sun Apr 14, 2013 12:46 pm
You will need to remove the booster from the relay box and solder some jumper wires.
Even at 50%, the signal is still 0-10vdc, with 50% duty cycle.
Sent from my Galaxy S3 using Tapatalk 2
Re: pwm voltage?
Posted: Sun Apr 14, 2013 12:59 pm
by pandimus
rimai wrote:You will need to remove the booster from the relay box and solder some jumper wires.
just jumper it straight across where the pins used to be? or is there an order?
Re: pwm voltage?
Posted: Sun Apr 14, 2013 1:09 pm
You need to remove lm358 and resistors.
Then, connect the in to out with jumper wires
Re: pwm voltage?
Posted: Sun Apr 14, 2013 1:28 pm
by pandimus
Will do thanks.
Re: pwm voltage?
Posted: Sun Apr 14, 2013 1:34 pm
I guess it was more involved than i thought :) sorry :)
Re: pwm voltage?
Posted: Sun Apr 14, 2013 1:52 pm
by pandimus
Not a problem at all.
Re: pwm voltage?
Posted: Sun Apr 14, 2013 3:29 pm
by pandimus
Easy mod.just De solder like said then connect jumpers from + volts in to out on both sides of the lm358...Thanks
pwm voltage?
Posted: Sun Apr 21, 2013 12:34 pm
by mls228
I have my relay box open now. Can you guys describe in terms of pins what to do? Thanks!
Re: pwm voltage?
Posted: Sun Apr 21, 2013 1:51 pm
Jumper 1 and 3 together and 5 and 7 together.
pwm voltage?
Posted: Sun Apr 21, 2013 6:09 pm
by mls228
rimai wrote:You need to remove lm358 and resistors.
Sorry to ask again. "Measure twice, cut once."
I'll remove R19, R20, R21, R22 and the LM358 (IC1), then jumper as described. Correct?
Re: pwm voltage?
Posted: Sun Apr 21, 2013 6:57 pm
Yes.
Re: pwm voltage?
Posted: Wed Jun 19, 2013 9:41 am
by baroutas
Roberto if i want change the actinic port from 0-10 to PWM and oposite what must do or remove?
Re: pwm voltage?
Posted: Wed Jun 19, 2013 10:04 am
Unless you have one of the latest board revisions (rev 8.1), it will be very hard for you to do this.
Re: pwm voltage?
Posted: Wed Jun 19, 2013 10:11 am
by baroutas
How can i see that? I order my RA Noveber 2012.
Re: pwm voltage?
Posted: Wed Jun 19, 2013 10:18 am
Opening the box, but I'm almost positive the rev 8.1 wasn't around at that time.
Re: pwm voltage?
Posted: Wed Jun 19, 2013 10:23 am
by baroutas
ok!!!Thanks Roberto!
Re: pwm voltage?
Posted: Thu Dec 05, 2013 11:28 pm
by mls228
Life got in the way but 8 months later I made this change and it works perfectly. Thanks Roberto. Image
