Wifi problems (setting up for the first time)
Posted: Sat Apr 20, 2013 2:26 pm
by Smotz
Need some help please.
Cant get my wifi module set up.
It connects to my WIFI & my DHCP server, obtains an IP, GW, etc. Blue light is off & Green is slow blink.
But It is unpingable and I cannot get to the web interface.
Help please.
<2.38.3> get i
IF=UP
DHCP=ON
IP=192.168.0.118:2000
NM=255.255.255.0
GW=192.168.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
<2.38.3> get w
SSID=MeanBiak-Wireless
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=XXXXXXX
Re: Wifi problems (setting up for the first time)
Posted: Sat Apr 20, 2013 3:23 pm
by Smotz
Ok - I made some progress.
If I change my WIFI to Open I was able to make it work.
What am I doing wrong - I cant keep my network on Open.
Posted: Sat Apr 20, 2013 3:35 pm
by Smotz
Fixed - TKIP instead of AES. Guess the wifi module doesn't like AES.
Can anyone advise how to set the ip on the wireless module to static?
Posted: Sat Apr 20, 2013 3:46 pm
I would just set a dhcp reservation on your router..but I'm pretty sure you can config it as static as well.
Not sure of the commands offhand thoug..
Posted: Sat Apr 20, 2013 4:13 pm
From manufacturer manual:
The firmware supports the following security modes:
• WEP-64 and WEP-128 (open mode only, NOT shared mode)
• WPA2-PSK (AES only)
• WPA1-PSK (TKIP only)
• WPA-PSK mixed mode (some access points, not all are supported)
I would also set DHCP reservation, but if you want to do it in the module:
set ip address 192.168.0.2
set ip gateway 192.168.0.1
set ip netmask 255.255.255.0
set ip dhcp 0
Posted: Sat Apr 20, 2013 6:29 pm
by Smotz
rimai wrote:From manufacturer manual:
set ip dhcp 0
Thank you so much.
