Dumb TEMP question
Posted: Mon Apr 22, 2013 11:23 am
by Smotz
I have a dumb temperature question:
When it (the wizard or portal) asks when to turn on the heat -
Do I put 50? so anything above 50 should be heated util it reaches the turn off temp?
Re: Dump TEMP question
Posted: Mon Apr 22, 2013 11:24 am
by the2ndtinman
No, put the lowest temp you want your tank to be.
Sent from my EVO using Tapatalk 2
Posted: Mon Apr 22, 2013 11:27 am
by Smotz
Thank you
by the2ndtinman
You bet.
Re: Dumb TEMP question
Posted: Tue Apr 23, 2013 5:56 am
by Smotz
More clarification please:
I want my temp between 78.5 and 80.5
My thermometer has a digital temp setting.
RA has its own settings.
What should I set and where?
Posted: Tue Apr 23, 2013 6:08 am
by Reddy
On the heater, set it a little above what you want your max temp to be. I keep my tank at 78, so my heater is set to 80. Depending on the accuracy of the heater, you may need to adjust the heater max temp to keep the heater on till the Reef Angel turns it off.
On the Reef Angel, I usually have a difference of .6 degrees between the on and off temp settings. Anything less and the relay sometimes will bounce on and off during a heating cycle.
For your preferred temp, set the heater to enough above 80.5 that the Reef Angel cycles it off before the heater cycles itself off, I would guess about 82. Then set the Reef Angel to turn heat on at 78.5 and off at 80.5. During a heat cycle, watch the heater to make sure it stays on till the RA cycles it off. If it doesn't stay on, turn the heater up a bit.
Dumb TEMP question
Posted: Tue Apr 23, 2013 7:20 am
For your heater function you'll use 78.5 and 80.5 as the arguments. You'll want your heater set to at least 80.5
Posted: Tue Apr 23, 2013 7:30 am
by Smotz
Perfect! Thank you both.
Posted: Wed Apr 24, 2013 4:09 am
by Smotz
lnevo wrote:For your heater function you'll use 78.5 and 80.5 as the arguments. You'll want your heater set to at least 80.5
Provided my code is stored in 'internal memory' I should be able to change the values via the portal - yes?
Posted: Wed Apr 24, 2013 7:12 am
by binder
yes, you should be able to.
Re: Dumb TEMP question - interesting find
Posted: Thu Apr 25, 2013 2:30 pm
by Smotz
Thank you everyone for the guidance.
He's some findings - my digitally controlled Aqua - Via 300w heater did not work in this configuration because the temp settings would reset whenever the unit would power off! Being the RA is controlling the temp - the heater would reset to 79 instead of 81 as I want it.
Solution - I had a Finnex digitally controller 300w that seems to retain the settings at power off.
Dumb TEMP question
Posted: Thu Apr 25, 2013 2:50 pm
Ouch! Thats annoying...
Why would anyone want a heater that loses its config when you lose power...wtf.
Posted: Thu Apr 25, 2013 3:52 pm
by Smotz
For controllers such as RA, I am thinking analog heaters are best.
