ATO Pump
Posted: Tue Apr 23, 2013 4:42 pm
by cjrudy
Does anyone know the max head for this pump ?
Re: ATO Pump
Posted: Tue Apr 23, 2013 4:51 pm
You should be able to get 6 feet without loss
Re: ATO Pump
Posted: Tue Apr 23, 2013 4:56 pm
by Sebyte
I was pumping over 10ft from the basement to the first floor before I installed the sump in the basement. Obviously the flow was reduced but still usable.
Re: ATO Pump
Posted: Tue Apr 23, 2013 4:59 pm
by cjrudy
That should work, need an alternative to my Aqualifter, about the same ml per minute but the aqualifter max head is 30"
Re: ATO Pump
Posted: Thu Apr 25, 2013 2:54 pm
by Sebyte
The flow at 10ft was much better than the Aqualifter at 3ft.
ATO Pump
Posted: Sat Apr 27, 2013 12:55 pm
by cjrudy
I got the pump, seems to work well but wow, is it loud, really loud. Also seems cheaply made but as long as it works.
Not sure I will be able to stand the noise though.
