port fwd help
Posted: Mon Apr 29, 2013 7:00 am
by riggeek
We just moved and have a new combo modem/wireless router (actiontec C1000A). I notice that my portal will not allow me to control my tank settings. My reef angel wifi has a ip of 192.168.0.8 and is set up for a static ip, and port fwd of port 2000. I am able to control the reef angel from 192.168.0.8:2000/wifi.
when i use http://www.yougetsignal.com/tools/open-ports/ it shows the port as closed
I am not sure what the problem is from here. Any ideas?
Re: port fwd help
Posted: Mon Apr 29, 2013 8:18 am
When you check port 2000, does it say open?
Re: port fwd help
Posted: Mon Apr 29, 2013 8:35 am
by riggeek
it said closed, i am very sure its a port forwarding problem but not sure what to check because the modem/ wifi router says the port is open.
Re: port fwd help
Posted: Mon Apr 29, 2013 8:37 am
It says remote ip 0.0.0.0
Maybe you should choose the specific option?
Re: port fwd help
Posted: Mon Apr 29, 2013 10:05 am
by riggeek
got the port to show open now. had to reset and reconfigure the modem. I am not sure way it would not work before
