Negative number in memory
So, i am storing my latitude and longitude in memory and getting an error displaying it im the web page. looks like a closing > is not being sent...
xena:~$ wget http://www.xxxxxxxx.com:2000/mi110
--2013-04-29 20:38:09--  http://www.xxxxxxxx.com:2000/mi110
Resolving www.xxxxxxxx.com... 98.113.xxx.xxx
Connecting to www.xxxxxxxx.com|98.113.xxx.xxx|:2000... connected.
HTTP request sent, awaiting response... 200 OK
Length: 15 [text/xml]
Saving to: `mi110'
100%[======================================>] 15          --.-K/s   in 0s
2013-04-29 20:38:10 (916 KB/s) - `mi110' saved [15/15]
This page contains the following errors:
error on line 1 at column 20: expected '>'
Below is a rendering of the page up to the first error.
xena:~$ cat mi110
<M110>-73</M110xena:~$
this is the error I get trying to display it..
I should add that it's working fine. I have not tried to update it the value...
Ok tried updating it...it dropped the negative value. :( Looks like I found a bug for sure..
Re: Negative number in memory
I think it's because the controller doesn't have checks for uninitialized memory
I did initialize it...from the ino i can read and write negative numbers fine...
It looks like the http logic is getting hung up on it..
Ahhh... Sorry...
I should have read the post better.
You saved a negative number and you are trying to read....
The web server will break on neg numbers... You are correct.
The extra character "-" will make the xml string be short by 1 character, which is the > bracket of the last tag
And writing it drops the negative..
Any ideas here or pointers. Do you think we can get around this? My only other option is to setup another set of variables to track whether it's a negative number or not.
Now that I can properly submit a git pull request... I don't mind working on this :)
It's easy to fix the neg return data.
It will be more complicated to do the writing through the /mb or /mi command. I'll have to look at the code again. Curt was the one who implemented it.
it can be more complicated doing the write, i guess i don't follow completely with what you are wanting to do. maybe I should read it more closely.
