Error when compiling InitialInternalMemory
Posted: Thu May 02, 2013 1:35 pm
by brettb
Hey guys I keep getting the following error when compiling the InitialInternalMemory or any other internal memory memory code generated by the wizard. I have tried deleting the \Users\brett\Documents\Arduino folder and re installing but no luck. What could be the issue?
Simple Menu
C:\Users\brett\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::SendData(byte)':
C:\Users\brett\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:640: error: 'pingSerial' was not declared in this scope
Re: Error when compiling InitialInternalMemory
Posted: Thu May 02, 2013 1:38 pm
Make sure you are using libs 1.0.5
Download the latest RA Installer from the website.
It has been updated a few days ago.
Posted: Thu May 02, 2013 1:46 pm
by brettb
rimai wrote:Make sure you are using libs 1.0.5
downloaded and installed the latest 1.0.5 tonight.
When I go to Tools/Reef angel libraries version it confirms that I am using 1.0.5
Posted: Thu May 02, 2013 2:00 pm
bug
Use this file instead:
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(15);
InternalMemory.MHOnMinute_write(30);
InternalMemory.MHOffHour_write(21);
InternalMemory.MHDelay_write(7);
InternalMemory.StdLightsOnHour_write(14);
InternalMemory.StdLightsOffHour_write(21);
InternalMemory.StdLightsOffMinute_write(30);
InternalMemory.DP1Timer_write(4);
InternalMemory.DP2Timer_write(4);
InternalMemory.LEDPWMActinic_write(20);
InternalMemory.LEDPWMDaylight_write(20);
InternalMemory.WM1Timer_write(10);
InternalMemory.WM2Timer_write(15);
InternalMemory.HeaterTempOn_write(766);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(774);
InternalMemory.ChillerTempOff_write(770);
InternalMemory.PHMax_write(830);
InternalMemory.PHMin_write(540);
InternalMemory.ORPMax_write(285);
InternalMemory.ORPMin_write(1400);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(50);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(100);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
InternalMemory.ATOExtendedTimeout_write(120);
InternalMemory.ORPMin_write(2050);
InternalMemory.ORPMax_write(450);
InternalMemory.ActinicOffset_write(30);
InternalMemory.CO2ControlOn_write(770);
InternalMemory.CO2ControlOff_write(760);
InternalMemory.PHControlOn_write(800);
InternalMemory.PHControlOff_write(810);
InternalMemory.AISlopeStartW_write(0);
InternalMemory.AISlopeEndW_write(100);
InternalMemory.AISlopeDurationW_write(60);
InternalMemory.AISlopeStartB_write(0);
InternalMemory.AISlopeEndB_write(100);
InternalMemory.AISlopeDurationB_write(60);
InternalMemory.AISlopeStartRB_write(0);
InternalMemory.AISlopeEndRB_write(100);
InternalMemory.AISlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartW_write(0);
InternalMemory.RadionSlopeEndW_write(100);
InternalMemory.RadionSlopeDurationW_write(60);
InternalMemory.RadionSlopeStartRB_write(0);
InternalMemory.RadionSlopeEndRB_write(100);
InternalMemory.RadionSlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartR_write(0);
InternalMemory.RadionSlopeEndR_write(100);
InternalMemory.RadionSlopeDurationR_write(60);
InternalMemory.RadionSlopeStartG_write(0);
InternalMemory.RadionSlopeEndG_write(100);
InternalMemory.RadionSlopeDurationG_write(60);
InternalMemory.RadionSlopeStartB_write(0);
InternalMemory.RadionSlopeEndB_write(100);
InternalMemory.RadionSlopeDurationB_write(60);
InternalMemory.RadionSlopeStartI_write(0);
InternalMemory.RadionSlopeEndI_write(100);
InternalMemory.RadionSlopeDurationI_write(60);
InternalMemory.DelayedStart_write(7);
InternalMemory.PHExpMax_write(2500);
InternalMemory.PHExpMin_write(500);
InternalMemory.WaterLevelMax_write(3575);
InternalMemory.WaterLevelMin_write(2875);
InternalMemory.IMCheck_write(0xCF06A31E);
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code");
I'll update the RA Installer with this new file.
Posted: Sat May 04, 2013 8:18 am
by brettb
InitialInternalMemory compiles fine now but any memory sketch generated by the wizard gives the same previous errors
Posted: Sat May 04, 2013 8:20 am
by brettb
Also, a bit off topic. T1 is not displaying on the graph on the LCD of the reef angel controller. What could cause this?
Posted: Sat May 04, 2013 8:49 am
I'm not able to replicate the error.
Can you post the code you are getting the errors?
Posted: Sat May 04, 2013 11:00 am
by brettb
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.OverheatTemp_write( 290 );
InternalMemory.HeaterTempOn_write( 248 );
InternalMemory.HeaterTempOff_write( 250 );
InternalMemory.ChillerTempOn_write( 255 );
InternalMemory.ChillerTempOff_write( 250 );
InternalMemory.ATOExtendedTimeout_write( 480 );
InternalMemory.ATOHourInterval_write( 0 );
Posted: Sat May 04, 2013 11:42 am
Ahhh.
Memory Settings... I missed that part....
Thanks for contributing and informing about the bugs
It is the same thing.... You must replace the entire #include up top with the new one.
The other alternative is use hard coded settings.
Wizard will also be fixed next update.
Posted: Sat May 04, 2013 12:57 pm
by brettb
No problem! =)
Iv just change the memory settings through the portal.
Posted: Mon May 06, 2013 4:40 pm
by carlii
Ok the internal code above complies now, but I do I use these new dosing pump functions?
Also how do I add code for the third dosing pump?
How does the old intenal memory code:
InternalMemory.DP1RepeatInterval_write( 360 );
InternalMemory.DP1Timer_write( 8 );
InternalMemory.DP2RepeatInterval_write( 360 );
InternalMemory.DP2Timer_write( 8 );
translate into teh new internal memory code:
InternalMemory.DP1OnHour_write(360);
InternalMemory.DP1OnMinute_write(8);
InternalMemory.DP2OnHour_write(360);
InternalMemory.DP2OnMinute_write(8);
Posted: Mon May 06, 2013 5:28 pm
They are the same thing...
For the 3rd doser, you can use this:
InternalMemory.DP3Timer_write(4);
InternalMemory.DP3RepeatInterval_write(60);
Posted: Mon May 06, 2013 5:37 pm
by carlii
So do I just ignore the dpon hour and minute?
Posted: Mon May 06, 2013 5:38 pm
Yeah, those memory locations are only used for a single dose schedule.
