installed my wifi/lost daylight pwm
Posted: Fri May 03, 2013 11:38 am
by pandimus
ok, so i installed my wifi module the other day, and the daylight pwm just stopped working. It shows it working on the angel, but i get no voltage on the leads. I also updated the librarys at the same time. Any idea where to start troubleshooting?
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.StandardHeater( Port1,750,790 );
ReefAngel.StandardLights( Port2,9,0,21,0 );
ReefAngel.StandardFan( Port3,771,800 );
ReefAngel.StandardLights( Port4,8,0,18,0 );
ReefAngel.MHLights( Port6,7,0,21,0,10 );
ReefAngel.DosingPumpRepeat( Port7,0,240,10 );
ReefAngel.DosingPumpRepeat( Port8,0,240,10 );
ReefAngel.PWM.SetDaylight( PWMSlope(9,0,17,0,0,60,60,0) );
ReefAngel.PWM.SetActinic( PWMSlope(8,0,18,0,0,100,60,0) );
ReefAngel.Portal( "pandimus" );
Re: installed my wifi/lost daylight pwm
Posted: Fri May 03, 2013 6:51 pm
I don't see anything wrong with the code.
Posted: Fri May 03, 2013 7:16 pm
by enigma32
I would try:
1) Without the WiFi attachment connected
2) (if #1 still fails) try the ControllerTester sketch.
3) (if #2 still fails) rebuild with the old libraries and verify that the problem was caused by upgrading.
Posted: Sat May 04, 2013 12:19 pm
by pandimus
enigma32 wrote:I would try:
Where do I find controller test sketch? How do I down grade library? Also I noticed the lighting menu is gone from the controller.what caused that?
Posted: Sat May 04, 2013 1:23 pm
by enigma32
I believe the controller test sketch should be in File > Examples, but I'm not positive because I use a very not-normal configuration here.
It looks like there are a few things that could make the Lighting menu go away...
It might actually be worth running through the wizard to double check that everything is configured as you want in there.
Otherwise I'm sorry to say I'm not yet familiar enough with RA yet to be able to help you further :-(
Posted: Sat May 04, 2013 3:15 pm
To get the standard menu back (which includes the lighting menu), you need to add this line after the ReefAngel.Init(); line in the loop() function:
Posted: Mon May 06, 2013 10:24 am
by pandimus
I've tried everything here except reverting library's.not sure how to do that.hey roberto, is it possible to burn out just one channel of the pwm?
Posted: Mon May 06, 2013 10:31 am
That's a possibility.
Posted: Mon May 06, 2013 6:06 pm
by pandimus
If i buy the pwm dimmer expansion will this affect it?
Posted: Mon May 06, 2013 6:29 pm
Can you test the channel using ControllerTester code?
File->Sketchbook->Example Codes
Posted: Mon May 06, 2013 7:07 pm
by pandimus
I did that the other day.and bad channel does nothing.good channel works fine.
Posted: Mon May 06, 2013 7:08 pm
You can replace the LM358 to fix the channel.
If you get the dimming expansion, it would give you 6 more channels.
Posted: Mon May 06, 2013 7:15 pm
by pandimus
I removed the lm358 to make my unit 5v
Posted: Mon May 06, 2013 7:17 pm
by pandimus
Which is the daylight pins on lm358 1&3 or 5&7?
Posted: Mon May 06, 2013 7:36 pm
5&7
