i think about what config i put in my future reef angel
in the day i use this fonction
ReefAngel.Timer[1].SetInterval(random(10,150));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.Toggle(Port6);
it is possible to have night mode for put the wavemaker on port 6 alway on and turn off the port 5
thank you
wavemaker nightmode
- Contact:
Re: wavemaker nightmode
Yes, it is possible. What time did you want "night mode" to kick in? When did you want it to run from?
What you can do is something like this:
That should turn on port6 at 8p and keep it on until 6a. Then from 6a to 8p it will toggle the ports based on the Timers. There may be an improvement with the timer functionality. I'm just going from memory on what I think is the way to handle it. If it's not, somebody will catch it and update it for me. I'll also look again later tonight to confirm (if there's not been an update).
if ( (hour() >= 20) || (hour() <= 6) ) // from 8p - 6a
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Off(Port5);
// during the day
