Temp probes
Cooterbrown
Temp probes
My temp prow went out so I ordered a 2 new ones since they're not too pricey. Got them and hooked them up with one on the sump, and one in the display for giggles. The only port that works in the first one. Are these nt plug and play or do I need to program it to let it know there's more than one temp probe? Didn't see it on the wizard
Cooterbrown
Re: Temp probes
How do I reboot it? Unplug it?
- Contact:
bencollinz
Re: Temp probes
they are PnP but what's your code? are you displaying ALL on your screen? as well as the "ports 1-3" aren't utilized the way you're imagining they are. the probes will be renumbered by the serial number on them. so even if you put SN:0001 in port 3 and SN:0003 in port 1; SN:0001 will be probe 1. capiche?Cooterbrown wrote:My temp prow went out so I ordered a 2 new ones since they're not too pricey. Got them and hooked them up with one on the sump, and one in the display for giggles. The only port that works in the first one. Are these nt plug and play or do I need to program it to let it know there's more than one temp probe? Didn't see it on the wizard
