Binary sketch size: 32,406 bytes (of a 32,256 byte maximum)
Can someone help me trim this down 150 bytes haha.
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port8 );
ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Port8 ) );
ReefAngel.StandardHeater( Box1_Port7 );
ReefAngel.StandardHeater( Box1_Port8 );
// Turn on Port 3 when the temp of T2 gets above 80.0 degrees
if ( ReefAngel.Params.Temp[T2_PROBE] >= 800 ) ReefAngel.Relay.On(Port3);
// Turn off Port 3 when the temp of T2 gets below 80.0 degrees
if ( ReefAngel.Params.Temp[T2_PROBE] < 780 ) ReefAngel.Relay.Off(Port3);
// Only turn on ATO and Koralia 8 for 20 minutes every hour.
if (minute()<=20)
ReefAngel.Relay.Off(Box1_Port4);
ReefAngel.Portal( "agentgreen", "" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_DARKKHAKI,39,54, 100 );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
