Temp probe reads Error
Posted: Wed May 15, 2013 9:28 pm
by markywmson
On all 3 ports I can't get any kind of reading on my temp probe. I will plug it in and reboot after each change and double check, but I did that last night and was getting errors across the board. In searching, it seems I may have a bad probe, but I don't have another one to check against.
Is there anything else I can do to rule anything out?
-mark
Re: Temp probe reads Error
Posted: Thu May 16, 2013 4:07 am
by Sebyte
The connection plug is often the issue.
Make sure that all the wire are connected to their pins. Also that the pins are firmly sitting in the plug.
Attach the plug to the RA temp port, and with a very small screw driver gently push each pin, from the wire end down onto the connector.
Hope this works for you, it did for me
Posted: Thu May 16, 2013 5:30 pm
by markywmson
It appears I just wasn't leaving it unplugged long enough to officially reset it. Left it unplugged for 2 minutes and booted up with the temp probe plugged in, and everything is working and happy now.
