New RA Setup Assistance
Posted: Thu May 16, 2013 5:45 am
by kirkwood
My RA+ with Wifi arrives tomorrow. Can someone please direct me to the most current install thread?
thanks.
Posted: Thu May 16, 2013 5:52 am
by dbmet
What kind of computer are you using? Pc or Mac? Have you downloaded the software from the Reefangel site?
http://www.reefangel.com/download.aspx
Re: New RA Setup Assistance
Posted: Thu May 16, 2013 6:06 am
by kirkwood
dbmet wrote:What kind of computer are you using? Pc or Mac? Have you downloaded the software from the Reefangel site?
PC. Yes I already downloaded and installed the RA software.
Posted: Thu May 16, 2013 7:26 am
by cosmith71
Check the download section for the manual. Pay close attention to the section "Loading your Initial Memory Settings". You have to do this or nothing else will work.
Post here if you need help!
Posted: Fri May 17, 2013 7:07 am
by kirkwood
In reviewing the RA Manual, can I skip the initial part about connecting the ph and temp probe, powering up the RA, and cycling through the menus with the joystick? Can I just go directly to connecting the RA to my computer, loading in the memory, and then getting right into the Wizard to generate my custom code?
Then after I load in the custom code, I can start in with getting the WiFi running??
Posted: Fri May 17, 2013 7:11 am
by cosmith71
Yep. Sounds like a plan!
Posted: Fri May 17, 2013 7:12 am
by kirkwood
Colin,
Does that Trendnet ip camera have an android app for viewing?
Posted: Fri May 17, 2013 7:35 am
by cosmith71
Yes, TRENDNet Cloud View. It's feature poor, but works.
Posted: Fri May 17, 2013 1:01 pm
by rossbryant1956
One of the things that I did when first starting was to go a little slower than you might like, but studied and implemented one thing at a time. That way I was sure what was causing a problem when things started not working like I expected. So to say:
1. Unpack and inspect
2. Power it up, load the initial memory settings as advised
3. Bring up one thing, a pump, a light, a temp probe, anything
4. Sit back, be proud, take a bow
5. Do another
6. repeat
Posted: Sat May 18, 2013 11:15 am
by kirkwood
I'm up and running with WiFi. So far so good.
Now I would like to know how to name my temperature probes so that on the RA display, portal, and droid app they say tank and room instead of T1 and T2. Also want to do the same thing to name my ports.
Posted: Sat May 18, 2013 11:27 am
by cosmith71
kirkwood wrote:I'm up and running with WiFi. So far so good.
The portal is easy. Just open up the portal and go to "labels". You can re-name everything there.
On the android app, it's under Settings, Controller Information, Labels. Or you can just hit "Download" from the Controller Information menu to download all your labels from the portal.
On the RA screen, it's more involved. Start here:
http://forum.reefangel.com/viewtopic.php?f=14&t=109
Hope this helps.
Posted: Sat May 18, 2013 7:37 pm
by kirkwood
Thanks Colin. I'm making steady progress. Got my Label going now.
