Do the kessil A360w light work off of a analog signal?
What signal does the WP-40 Pump use?
Right now I have a PWM relay box and was trying to figure out the best way to control this set up.
I also have the alarm buzzer set up and would like to keep that function working
thanks
Controllable WP-40 Pump and kessil A360W lights
riggeek
- lnevo
I believe the kessil is analog. The wp-40 can take either signal. I recommend you keep what you have and get the dimming module to run the kessil and wp-40
paulvisco
Re: Controllable WP-40 Pump and kessil A360W lights
kessil interface operates within a 0-10Vdc 10VDC range
keep in mind that the PWM is still 10 vdc but the duty cycle is adjusted which gives the impression with a dvm that it is 0 to 10v..
The analog is best for the Kessil.
