How would I add an expansion relay to my code? Would I need to run through the wizard again? I have custom code for nutrient transport and also a random wave generator. How would I get these codes back in if I ran through the wizard.
Thanks!!
Adding an expansion relay
Spotted
Re: Adding an expansion relay
You can just add the code to the existing one you have.
To reference the ports on the expansion box, use Box1_Port1 through Box1_Port8
bencollinz
for your reference...
ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
