I found this code, posted by deckoz2302, of a really nice looking custom main screen.
//Custom Main, Graph & Menu
Wire.requestFrom(8,8);
for (int a=0;a<8;a++)
if (Wire.available()) SeasonsVar[a]=Wire.receive();
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 40, 68, 10);
ReefAngel.LCD.DrawText(0,255,70,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 99, 68, 10);
ReefAngel.LCD.DrawText(0,255,8,97,"Moon");
DayAge = MoonAge(day(), month(), year());
MoonState(DayAge);
if (ThisPhase == 0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"New");
else if (ThisPhase == 1) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Crescent");
else if (ThisPhase == 2) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"First Quarter");
else if (ThisPhase == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Gibbous");
else if (ThisPhase == 4) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Full");
else if (ThisPhase == 5) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Gibbous");
else if (ThisPhase == 6) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Last Quarter");
else if (ThisPhase == 7) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Crescent");
// ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 105, 109, 1);
ReefAngel.LCD.DrawText(0,255,8,109, "Sunrise");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,119, SeasonsVar[1]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,119, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,25,119, SeasonsVar[2]);
ReefAngel.LCD.DrawText(0,255,75,109,"%");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255, 60, 109, SeasonsVar[0]);
ReefAngel.LCD.DrawText(0,255,88,109, "Sunset");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,119, SeasonsVar[3]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,102,119, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,107,119, SeasonsVar[4]);
Here is my current code running on my RA +
ReefAngel.WaterChangePorts = Port5Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,13,0,0,0 );
ReefAngel.StandardLights( Port2,12,30,0,30 );
ReefAngel.DosingPumpRepeat( Port3,0,120,60 );
ReefAngel.DosingPumpRepeat( Port4,29,120,60 );
ReefAngel.StandardHeater( Port6,780,792 );
if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) ); // Tidal Swell at 60% on anti-sync mode
else if (hour()>=12 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% + - 20 on anti-sync mode
else if (hour()>=16 && hour()<17)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(75,90,2000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=17 && hour()<20)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 75% + - 20 on anti-sync mode
else if (hour()>=20 && hour()<24)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,40,10,false) ); // Long pulse at 40% with 10s pulse on on anti-sync mode
