Cant upload with USB power cable
ReeferBee
I keep getting the serial port com 3 error. I have tried all 4 usb ports on my laptop. Any idea? the head unit does power on but cant upload to it. I'm using a windows 8 laptop
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
Re: Cant upload with USB power cable
Can you post the error code?
Do you have any other serial port listed on menu Tools->Serial Port?
ReeferBee
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
Moon Phase Label
Standard Menu
Binary sketch size: 45,078 bytes (of a 258,048 byte maximum)
processing.app.SerialNotFoundException: Serial port 'COM3' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.<init>(Serial.java:191)
at processing.app.Serial.<init>(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:172)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1857)
at processing.app.Sketch.exportApplet(Sketch.java:1810)
at processing.app.Sketch.exportApplet(Sketch.java:1783)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2357)
at java.lang.Thread.run(Thread.java:619)
"Serial port 'COM 3' not found" in orange at the bottom of the window.
Is that what you need? I cant select serial port in the tools menu, its greyed out. This happened to me once before but I just used the ttl cable and upload was successful.
Barry
If it is grayed out, it means the computer didn't find the cable.
Make sure you plug in the USB-TTL cable and check if the drivers are installed correctly too.
- cosmith71
You are using the USB power cable AND the TTL cable, correct?
ReeferBee
I am not. Guess that's my problem huh? Thanks!
Barry
- cosmith71
You're welcome.
jgwinner
I know this is an old thread, but there's nothing in the documentation (downloaded V2.1.5) to show where/how to plug in the USB power cable. It LOOKS like the only place is say the temperature probe, but would prefer not to let magic smoke out
It's tiring moving the relay box over to the PC every time I program ...
I would suggest modifying the owners manual.
== John ==
== John ==
- cosmith71
It is the temperature probe port.
jgwinner
Yep, no magic smoke on my end o.O
thanks! Funny it's not documented though. Let's fix that!
Thank you,
== John ==
Thank you,
== John ==
