How accurate is the temp probe reading? My temp always seems to read a couple of degrees higher than temp readings I get from other sources like ranco chiller controller, corallife lcd temp probe, and old aquacontroller 2.
I needed some longer probes so I got a couple of 3 meter DS18B20 temp probes from china and they're reading the same as my original RA probes so I don't think it's a DS18B20 issue.
I stuck each in some water I warmed to about 100F to see if they tracked the same at higher temps and each was within a couple tenths of a degree. Then I put them back in my 80F tank water and the DS18B20 probe was reading high again.
Could there be an accuracy issue with the Celsius to Fahrenheit conversion?
Temp probe accuracy
Re: Temp probe accuracy
They are pretty accurate in mind point of view and experience.
In the datasheet, they say +/- 0.5C
I don't think conversion is an issue, but if you are interested in looking over, here is the code:
Temp = Temp * 1.8 + 320;
