PWM
Posted: Sun Oct 02, 2011 5:45 am
I have some questions about the PWM connectors built into the relay box.
1. Those connectors just have a + & -, so they can be connected to just like with the expansion. The only difference is we don't need an additional 12V power source to it, correct?
2. What type of connector is needed for it? I have the 1st gen and another 2nd gen relay.
Re: PWM
Posted: Sun Oct 02, 2011 8:07 am
1. Although you don't need the 12VDC power source, you do need the booster for older relay boxes, including your gen 1 and 2.
2. http://forum.reefangel.com/viewtopic.ph ... gikey#p513
Re: PWM
Posted: Thu Feb 23, 2012 4:21 pm
by rafamar
rimai wrote:1. Although you don't need the 12VDC power source, you do need the booster for older relay boxes, including your gen 1 and 2.
what is booster???
thx
Re: PWM
Posted: Thu Feb 23, 2012 4:35 pm
Some that comes built in on all relays boxes for a while now.
It's was an optional item in the past.
