standard menu not working
Posted: Sun May 26, 2013 10:05 am
I've uploaded the standard menu so i can change things on the fly without changing the code. the menu comes up fine on the RA but when I change temperature settings, lighting schedule, or wavemaker timing, nothing actually changes as it should.
here is my code.
any help is appreciated
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 833 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardATO( Port1,242 );
ReefAngel.StandardLights( Port2,21,0,9,0 );
ReefAngel.StandardLights( Port3,8,0,22,30 );
ReefAngel.StandardLights( Port4,9,0,22,0 );
ReefAngel.WavemakerRandom( Port6,8,30 );
ReefAngel.StandardHeater( Port7,779,797 );
ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,10 );
ReefAngel.Portal( "reefangel" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
here is my code.
int x,y;
// Relay Expansion
