wp40 codes
jjdezek
wp40 codes
im looking for different codes for the wp40 that i can toggle between, like nutrient export, reef crest and so on. right now i have one mode but i would like to have a few to switch between.
ReeferBee
Re: wp40 codes
Here's mine
if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) ); // Tidal Swell at 60% on anti-sync mode
else if (hour()>=12 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% + - 20 on anti-sync mode
else if (hour()>=16 && hour()<17)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(75,90,2000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=17 && hour()<20)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 75% + - 20 on anti-sync mode
else if (hour()>=20 && hour()<24)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,40,10,false) ); // Long pulse at 40% with 10s pulse on anti sync mode
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
jjdezek
jjdezek
Re: wp40 codes
thats not working for me...it gives me an error outside that code, but without that code it runs fine. you have that running on your system?
ReeferBee
Re: wp40 codes
You cannot change the modes on the fly with this code. It just runs different modes thoughout the day. I believe someone has code where you can change modes on the menu screen.
I am running this, are you putting it in the right spot?
Barry
jjdezek
ReeferBee
Re: wp40 codes
That's right. Strange
ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,40,10,false) ); // Long pulse at 40% with 10s pulse on on anti-sync mode
Barry
jjdezek
Re: wp40 codes
on this code what is the pump running at? i want the max to be 100%, is it saying the max is 75 or 90?
- lnevo
cgonser
Re: wp40 codes
Got my 2 wp-40s up and running, is there a way to get them to go to half power in the evening? Kind of like a night mode? Here is my code....
ReefAngel.LightsOnPorts = Port4Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.SingleATOLow( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port8 );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
ReefAngel.DCPump.ExpansionChannel[1] = AntiSync;
ReefAngel.Portal( "cgonser" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
ReefAngel.LCD.DrawText( COLOR_BLUE,DefaultBGColor,x,y,"Ch :" );
ReefAngel.LCD.DrawText( COLOR_BLUE,DefaultBGColor,x+12,y,a );
ReefAngel.LCD.DrawText( COLOR_BLUE,DefaultBGColor,x+24,y,ReefAngel.PWM.GetChannelValue(a) );
y += 10;
