Coding for Fresh Water Tank.
Posted: Sat Jun 01, 2013 11:58 pm
by abhi_123
Hi I am planning to use my reef angel controller to control my 2 planted tank.
i will be using this code
// Autogenerated file by RAGen (v1.2.2.171), (06/02/2013 11:59)
// RA_060213_1159.ino
// This version designed for v0.9.0 or later
/* The following features are enabled for this File:
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port7);
    ReefAngel.MHLights(Port1);
    ReefAngel.MHLights(Port2);
    ReefAngel.StandardFan(Port3);
    ReefAngel.StandardFan(Port4);
    ReefAngel.Wavemaker1(Port6);
    ReefAngel.StandardHeater(Port8);
    // This sends all the data to the portal
    // Do not add any custom code that changes any relay status after this line
    // The only code after this line should be the ShowInterface function
    ReefAngel.Portal("abhi_123", "75HRSNAHMLYUS");
Port no. 1 & 2 will be used for the lights, 3 & 4 will be either chiller or fan, 5 & 6 are filteration, 7 will be to control Co2 or Ph, 8 will be for heater.
I want to set the timing of light between 9:00 am to 6:00 pm, fans & heaters to be set as to maintain temp between the range of 24 degree to 27 degree, ph to be around 6.8.
What amendment is required in above code to work as it.
Re: Coding for Fresh Water Tank.
Posted: Sun Jun 02, 2013 6:16 am
by rossbryant1956
I use the wizard as a starting place for all my new code ideas, then edit it (or ask questions) to get that last mile done. Try it. Thx
Posted: Sun Jun 02, 2013 10:26 am
by abhi_123
Thanks for the advice but tool option of my arduino is not opening.
