Rope Leak Detector Expansion
Hey Guys,
I'm very proud to have this rope leak detector expansion released!!!
It's in pre-order at an introductory price of $99, which includes 16ft of rope leak sensor and the 12VDC power supply.
You can use it as an expansion module for your Reef Angel system and turn off ports if a leak condition is encountered or you can also use it as stand alone. It has an audible alert that will notify you of a leak condition.
You can daisy chain the rope to have almost 50ft of leak detection.
Don't just check for single spots.... Check it for the entire length of the rope!!!
http://www.reefangel.com/productview.as ... rexpansion
And here is a short video of the Rope Leak Detector working as stand alone. Of course, you can connect it to your Reef Angel system by using one of your expansion ports and code it to turn off return pump or skimmer, for example.
[youtube]http://www.youtube.com/watch?v=7lQ7h2BkboA[/youtube]
Re: Rope Leak Detector Expansion
Awesome!!! Gonna need to save up for this one!!
jsclownfish
Post by jsclownfish »
all these new toys! :) You've been busy. :geek:
Does the rope leak use the 12V controller relay or is that an independent source.
-Jon
It works with its own power supply, which comes with the module.
Sent from my SPH-L710 using Tapatalk 4 Beta
kevingehrke
Post by kevingehrke »
The Add to Cart link for the additional rope links to the Dimmable Lunar Hub.
Great expansion, I hate wet floors.
Thanks for informing.
It's fixed now :)
I posted a youtube of the module in action to the original post.
coolbird
Post by coolbird »
What an excellent idea
Gotta get me one of those :-)
