Wifi Setup Question
Posted: Tue Oct 04, 2011 9:32 am
I ran the setup code under the downloads section and it seemed to work fine. My IP was assigned, I can ping it, and also http to it (Reef Angel Controller Web Server). Problem I currently have is no internet access (slow green blink only). Is there a way to telnet to the device over the LAN to check/edit config settings? I tried using the manual teraterm method as well, but nothing displays during step 16 for the teraterm readout. Not sure what I'm missing...here's my pde and mem config. #define wifi is also in my RA_Features.h file.
Thanks in advance!
PDE:
MEMORY:
Thanks in advance!
PDE:
// Autogenerated file by RAGen (v1.0.4.92), (09/08/2011 09:54)
// RA_090811_0954.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Daylight 1
#define Chiller 2
#define Heater 3
#define Return 4
#define WavemakerL 5
#define WavemakerR 6
#define LED 7
//#define ATO 7
#define Refugium 8
randomSeed(analogRead(0)); //wm stuff
ReefAngel.FeedingModePorts = B00001000;
ReefAngel.WaterChangePorts = B00000000;
ReefAngel.OverheatShutoffPorts = B00000101;
ReefAngel.LightsOnPorts = B00000001;
ReefAngel.Relay.On(Return); //port 4
//wm stuff
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(WavemakerL);
// Specific functions
ReefAngel.StandardFan(Chiller,775,783);
ReefAngel.StandardHeater(Heater,768,775);
ReefAngel.StandardLights(Daylight,8,45,19,30); //Daylight schedule 9:00am - 7:30pm
ReefAngel.StandardLights(Refugium,21,0,9,0); //Refugium schedule 9:00pm - 9:00am
ReefAngel.StandardLights(LED,8,30,22,0); //LED schedule 8:45am - 10:00pm
//Wavemaker stuff
ReefAngel.Relay.Toggle(WavemakerL); //port 5
ReefAngel.Relay.Toggle(WavemakerR); //port 6
/* ATO stuff
if(ReefAngel.LowATO.IsActive())
ReefAngel.Relay.On(ATO); //port 7
ReefAngel.Relay.Off(ATO);
// Autogenerated file by RAGen (v1.0.4.92), (09/08/2011 09:59)
// Memory_090811_0959.pde
#include <Phillips6610LCDInv.h>
#include <avr/pgmspace.h>
Phillips6610LCDInv e;
e.lcd_init();
e.lcd_clear(COLOR_WHITE,0,0,132,132);
e.lcd_BacklightOn();
InternalMemory.MHOnHour_write(8);
InternalMemory.MHOffHour_write(15);
InternalMemory.StdLightsOnHour_write(9);
InternalMemory.StdLightsOffHour_write(21);
InternalMemory.DP1OnHour_write(4);
InternalMemory.DP1Timer_write(0);
InternalMemory.DP2Timer_write(0);
InternalMemory.FeedingTimer_write(150);
InternalMemory.LEDPWMActinic_write(50);
InternalMemory.LEDPWMDaylight_write(50);
InternalMemory.WM1Timer_write(30);
InternalMemory.WM2Timer_write(30);
InternalMemory.HeaterTempOn_write(767);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(780);
InternalMemory.ChillerTempOff_write(770);
// display the values
char buf[128];
sprintf(buf, "MH %2d:%02d-%2d:%02d,%d", InternalMemory.MHOnHour_read(), InternalMemory.MHOnMinute_read(),
InternalMemory.MHOffHour_read(), InternalMemory.MHOffMinute_read(),
InternalMemory.MHDelay_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW, buf);
sprintf(buf, "Std %2d:%02d-%2d:%02d", InternalMemory.StdLightsOnHour_read(), InternalMemory.StdLightsOnMinute_read(),
InternalMemory.StdLightsOffHour_read(), InternalMemory.StdLightsOffMinute_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, buf);
sprintf(buf, "LED A: %d%% D: %d%%", InternalMemory.LEDPWMActinic_read(), InternalMemory.LEDPWMDaylight_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*3, buf);
sprintf(buf, "WM1: %ds", InternalMemory.WM1Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, buf);
sprintf(buf, "WM2: %ds", InternalMemory.WM2Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, buf);
sprintf(buf, "F: %ds", InternalMemory.FeedingTimer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*6, buf);
sprintf(buf, "S: %ds", InternalMemory.LCDTimer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*7, buf);
sprintf(buf, "H On: %d -> %d", InternalMemory.HeaterTempOn_read(), InternalMemory.HeaterTempOff_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*9, buf);
sprintf(buf, "C On: %d -> %d", InternalMemory.ChillerTempOn_read(), InternalMemory.ChillerTempOff_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*10, buf);
sprintf(buf, "PH %d - %d", InternalMemory.PHMax_read(), InternalMemory.PHMin_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*11, buf);
delay(10000);
sprintf(buf, "OH: %dF", InternalMemory.OverheatTemp_read());
sprintf(buf, "ATO L: %ds (%dh)", InternalMemory.ATOTimeout_read(), InternalMemory.ATOHourInterval_read());
sprintf(buf, "ATO H: %ds (%dh)", InternalMemory.ATOHighTimeout_read(), InternalMemory.ATOHighHourInterval_read());
sprintf(buf, "DP1: %2d:%02d", InternalMemory.DP1OnHour_read(), InternalMemory.DP1OnMinute_read());
sprintf(buf, " %ds", InternalMemory.DP1Timer_read());
sprintf(buf, "DP2: %2d:%02d", InternalMemory.DP2OnHour_read(), InternalMemory.DP2OnMinute_read());
sprintf(buf, " %ds", InternalMemory.DP2Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*8, buf);
delay(10000);
