Weird Wifi Setup Issues
Posted: Fri Jun 14, 2013 1:41 pm
by mvwise
I have previously been able to connect my wifi module to our network but ran into some of the same issues with the wifi dropping out that affected others. I have no updated the firmware to version 4 and have gone through the setup process again. Now I get a fast flashing green and flashing blue at the same time.
However, my network show the device connected, the terminal dump shows an IP address assigned and connected to the network, but it doesn't seem to be working.
Here is the terminal dump:
CMD
get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=192.168.2.24:2000
NM=255.255.255.0
GW=192.168.2.1
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.2.1
Name=dns1
Backup=rn.microchip.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=Wiseguys
Chan=0
ExtAnt=0
Join=0
Auth=WPA1
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=86031681
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Any thoughts as to where I am going wrong?
Re: Weird Wifi Setup Issues
Posted: Fri Jun 14, 2013 1:50 pm
IF=DOWN means the connection is down.
I'd highly recommend using WPA2-PSK with AES encryption. I've heard some people having issues on WPA1 and my speculation is that it will only accept WPA1-PSK with TKIP encryption. I can't confirm though.
WPA2 is more secure anyway, so you should think about bumping up.
Both SSID and passphrase are case sensitive.
But most importantly, there is a big step buried in the manual that needs to be accomplished or you won't connect.
http://forum.reefangel.com/viewtopic.php?p=23931#p23931
Posted: Fri Jun 14, 2013 2:19 pm
by mvwise
Awesome, thanks!
I generally use WPA2-PSK but was having a hard time connecting and thought that might be it. Forgot to change it back.
Apparently this is not in the manual that I'm reading on the downloads page. Where is this new manual located?
Posted: Fri Jun 14, 2013 2:48 pm
Oh, it is in the manufacturer's manual.
http://www.rovingnetworks.com/resources ... ser_Manual
Posted: Sun Jun 16, 2013 12:32 pm
by Poiromaniax
not really the solution to this issue, but do yourself a favour and reserve an address for your wifi unit in your modem/router.
From a networking point of view, it is less troublesome......
