Page 1 of 9
PaulTurner911 Code
Posted: Fri Jun 14, 2013 3:12 pm
by Paulturner911
First I would have to thank Lee for "helping" get this dialed in.....
AND BY HELP I MEAN PRETTY MUCH DO IT FOR ME!!
He has been a great help in this from the start.
Currently Running:
Overflow Protection- Shuts down Return Pump
ATO Low Protection- Shuts down Aqua Lifter
Moon Phase from 9pm-10am
ATO/Kalk Doser running for 50sec every 15min from 8pm-12pm
Custom Feed Mode(WP40 off for 30min, Return Pump off for 60min)
WP40 Tidal Modes (Randomized Daily)
Night Mode for the WP40
ReefAngel.FeedingModePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2 );
ReefAngel.DayLights( Port7 );
ReefAngel.DayLights( Port8 );
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Pump Delay and Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 50sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<50);
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
if (!feeding)
feeding=true;
} else {
feeding=false;
///// Place your custom code below here
//IDK Rimai Posted
#define Mem_B_RFMode VarsStart+55
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=25;
int maxOffset=25;
int min=speed-minOffset;
int max=speed+maxOffset;
// Add random mode if we set to Mode to 12
static int rmode;
if (now()%SECS_PER_HOUR==0) {
rmode=random(7); // Change the mode once per hour to modes 0-6
if (mode==12) {
mode=rmode;
// keep wavemakers off for first 30 minutes of feeding mode.
if (now()-feedingstarted<=1800 && ReefAngel.DisplayedMenu==FEEDING_MODE) {
ReefAngel.PWM.SetDaylight( 0 );
//ReefAngel.PWM.SetActinic( 0 );
} else if (mode==Constant) {
// Constant
ReefAngel.PWM.SetDaylight( speed );
//ReefAngel.PWM.SetActinic( speed );
} else if (mode==Lagoon) {
// Lagoon
ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
} else if (mode==ReefCrest) {
// Reef Crest
ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
//ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
} else if (mode==ShortPulse) {
// Short Pulse
ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( ShortPulseMode(min,max,duration,false) );
} else if (mode==LongPulse) {
// Long Pulse
ReefAngel.PWM.SetDaylight( LongPulseMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( LongPulseMode(min,max,duration,false) );
} else if (mode==TidalSwell) {
// Tidal Swell
ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,true) );
//ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,false) );
} else if (mode=NutrientTransport) {
// Smart_NTM
ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
//ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
} else {
// Default
ReefAngel.PWM.SetDaylight( TideMode(speed,minOffset,maxOffset) );
//ReefAngel.PWM.SetActinic( TideMode(speed,minOffset,maxOffset) );
// Add night mode (constant 30%)
if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY >=81000) { // Time is before 8:30am and after 10:30pm
ReefAngel.PWM.SetDaylight(30);
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
http://forum.reefangel.com/status/chart ... ilter=PWMD
Re: PaulTurner911 Code
Posted: Mon Jun 17, 2013 8:55 am
Try this code, I added the following requested features:
Changed random mode to switch daily instead of hourly
Changed the duration for NTM and short pulse to use a better value (duration * 100) since the argument is milliseconds
Added in the NTM after feeding mode is done. (30 minutes pumps off, then 60 minutes of NTM)
Added indentations to make it readable.
//ATO Protection
//IDK Rimai Posted
// #define Mem_B_RFMode VarsStart+55
int minOffset=25;
int maxOffset=25;
static int rmode;
if (now()%SECS_PER_DAY==0 || changeMode=true) { // Change at midnight or if controller rebooted
rmode=random(7); // Change the mode once per day to modes 0-6
changeMode=false;
if (mode==12) {
mode=rmode;
static unsigned long feeding;
feeding = now();
if (now()-feeding<=1800) { // 30 minutes after
} else if (now()-feeding<=(1800+3600)) { // // First 30 minutes pump is off.. next 60 minutes will be in NTM
ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration*100,true) );
} else if (mode==Constant) { // Constant
} else if (mode==Lagoon) { // Lagoon
} else if (mode==ReefCrest) { // Reef Crest
} else if (mode==ShortPulse) { // Short Pulse
ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration*100,true) );
} else if (mode==LongPulse) { // Long Pulse
} else if (mode==TidalSwell) { // Tidal Swell
} else if (mode=NutrientTransport) { // Smart_NTM
} else { // Default
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Posted: Mon Jun 17, 2013 2:35 pm
by Paulturner911
Error:
Ivalue required as left operand of assignment
Posted: Mon Jun 17, 2013 2:38 pm
It need == instead of =
Posted: Mon Jun 17, 2013 3:36 pm
by Paulturner911
Error
expected unqualified-id before "if"
Posted: Mon Jun 17, 2013 3:45 pm
Its this line above that...
It needs a {
Posted: Mon Jun 17, 2013 5:25 pm
by Paulturner911
Thanks guys, it took!!
Lee, what is your duration set at?
If I understand(rarely) I would set it at 25 inorder for reefcrest to run @45 +/-25.
I did this in the portal, while saving all read "OK" but DC Pump Speed & Duration- both ERR
Posted: Mon Jun 17, 2013 6:52 pm
The libraries arent supporting dc pump yet.
Posted: Mon Jun 17, 2013 7:34 pm
by Paulturner911
k, just seemed sketchy.
When I select custom in the portal ive only run 45 tonight no change (maybe it randomized 45 constant), Ill check to see if it changes tuesday. Night mode does work though! Just watched it click over.
Could I just remove ones that I dont want to run from this section??
} else { // Default
Posted: Mon Jun 17, 2013 7:43 pm
If you pick custom it will just do the tide mode which is almost a constant, unless you changed the mode==12 line.
Otherwise set the RFMode memory to 12 manually.
Posted: Mon Jun 17, 2013 7:48 pm
And it's very likely to have picked constant, it's only 1 in 7
Posted: Mon Jun 17, 2013 7:53 pm
by Paulturner911
// Add random mode if we set to Mode to 11(Custom in Portal)
static int rmode;
changeMode=false;
if (mode==11) {
mode=rmode;
This should have made custom do my random function correct?
Posted: Mon Jun 17, 2013 7:56 pm
Yep
Posted: Mon Jun 17, 2013 8:02 pm
by Paulturner911
We will know tomorrow. How can I remove modes?....like this lol
Posted: Mon Jun 17, 2013 8:05 pm
Well I would not take them out of your list of modes. You'll just end up in your default else more often..l
I'll post some code tomorrow you can use to pick which ones get used for random mode.
Posted: Tue Jun 18, 2013 11:32 am
by Paulturner911
I does seem to have picked a different mode today!! Maybe long pulse. I have 45 for speed and 25 for duration in the portal. I see that there is a tab for DC pump now, will I be utilizing that? BUT there isnt a "custom" selection. What is your duration set at Lee? I would like my PWM graph to look a bit more like yours.
Posted: Tue Jun 18, 2013 11:40 am
I set my duration to 10 but I am doing things very differently. I don't have wp40s.
The dc pump section will be supported by the new libraries. I have no idea how that is going to work yet.
Posted: Tue Jun 18, 2013 11:49 am
by Paulturner911
I see! Maybe thats why its so flat. Ive set mine to 10. I just think Im going to end up wanting to randomize lagoon, reefcrest and long pulse. Im stoked to try NT after feedmode tonight!!!
Posted: Tue Jun 18, 2013 11:57 am
The new libs have been pushed yesterday
Take a peak at the wizard.
Posted: Tue Jun 18, 2013 12:02 pm
by Paulturner911
Cool! Ill check it out when I get home.
Posted: Tue Jun 18, 2013 12:15 pm
by Paulturner911
OK, I jumped the gun and downloaded it at work.
I see in the wizard that you can set the mode, but I see no duration and no "custom" mode. Duration IS in the portal, but still no custom. Will I have a wat to select and randomize Lagoon, ReefCrest, and Long Pulse?
Posted: Tue Jun 18, 2013 12:27 pm
I suspect a lot will have to be changed (maybe it will be easy...) in order to incorporate the things we've done. However since it's all in the wizard it might be best to start fresh and go from there... just something to keep in mind.
Posted: Tue Jun 18, 2013 12:28 pm
Duration is only available on certain modes.
No custom with the wizard
If you are doing custom, you don't need the wizard
Posted: Tue Jun 18, 2013 12:34 pm
But he wants to utilize the DC Pump portal section... I think it be easiest to start with that fresh from the wizard and add his custom stuff back in after.
Also, off topic, but I had no idea new code was pushed
The sticky with the changelog doesn't show up in New Posts. Can you bump it in the future when a new release is made.
Posted: Tue Jun 18, 2013 12:37 pm
by Paulturner911
I think Im going to stick with what Im running and possibly (with Lees help) come up with a way to randomize specific modes. I dont see much difference in the DC or the Vortec menus.....What would I gain in changing?
Posted: Tue Jun 18, 2013 12:51 pm
I just looked at the changes made in the libraries. It will be much easier to do everything with that because your whole if else block to look at the functions is all part of the ReefAngel class now.
You've got a lot of custom stuff so yeah, for you it might be easier to leave it for now, once I see how the new stuff is used, I can help you transition to it.
The main benefit will be that since you don't have a RF module, your using the memory locations, but your not tracking changes to speed duration and mode in the portal charts. (i.e. You can't do a chart on RFS for instance (RFSpeed). You can't even look at what that variable has been set for because the portal doesn't track memory addresses.
With the new libraries, the DCS (DC Speed) is now reported by /r99 and will be part of the XML sent to the portal, so you'll be able to view exactly what state your DC Pump is in and not just look at the PWMD output.
Also, since we'll be doing random modes each day you can track what your DCD value looks like to know which mode your controller chose that day
Lots of cool things.
Posted: Tue Jun 18, 2013 1:34 pm
by Paulturner911
I like the idea of being able to identify what mode it IS or WAS in!! Please keep me posted.
Posted: Wed Jun 19, 2013 8:31 am
by Paulturner911
LOL, back in DEFAULT. UGH!!
Ill wait it out a few, and dabble in the wizard to see what I can do on my own this weekend..... I should be able to get my basic stuff back in after running the wizard, then Ill work on the WP40 stuff.
Posted: Wed Jun 19, 2013 7:24 pm
by Paulturner911
Ive run the wizard and stuck all of the custom in that I thought would not conflict. Basically everything with the exception of the custom feed mode and the custom randomized WP mode. The following was what I would like modified to work with the DC
if (!feeding)
feeding=true;
} else {
feeding=false;
//IDK Rimai Posted
int minOffset=25;
int maxOffset=25;
static int rmode;
if (mode==12) {
mode=rmode;
// Constant
// Lagoon
// Reef Crest
// Short Pulse
// Long Pulse
// Tidal Swell
// Smart_NTM
} else {
// Default
by Paulturner911
Here is my current DC CODE
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH2
//Over Flow Protection
//ATO Protection
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
